Question about Dell Computers & Internet
Dell Poweredge 700 Server problems
Booting up, runs through a few stages then I get this loud beep with a message about Raid 5 arrays invalid. Loud beep remains constant then the server shuts down. Any advice?
  • 61 Answers
Dear jckim, Which server you are using? Usually this error occurs when raid controller card have some problem.Have you getting any error codes?
Posted on Oct 23, 2008
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
Dell poweredge 2600 server recently display a message " No boot device available Press F1 to reboot or F2 to setup" Please why?
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Aug 03, 2010 | Dell PowerEdge 2600 Server
Dell poweredge 1650 is beeping with blue flashing light
Flashing blue light is harmless - it simply means the Identify button has been pushed. There is a small button with a white, cursive 'i' on the front and back of the server - pressing this will make the light flash blue (or make it stop).
Go to Dell's support site and view the manual for the 1650 for an explanation of the beep code - identify the pattern of the beep.
If you are still able to get to Windows, use OpenManage Server Administrator to check the Hardware logs and RAID array.
May 20, 2010 | Dell PowerEdge 1650 Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
The Dell 2950 Server we have cannot reboot the disc drives
The raid may be fine you need to reinstall the OS.
The best way is to drop the raid array astablish a new raid array then install you new OS on a new raid array.Very nice server you have.
Oct 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
Aug 22, 2009 | Computers & Internet
Dell Poweredge 4300 Bootup problem after cmos battery replacement
Check the version for the Raid Controller. This may need to have the firmware to be upgraded. If the controller is removable, take the controller out and then see if the computer will continue past the bios. If the controller is built-in, then disable it in the bios, and try to see if it will get past the controller setup.
On most system I have worked with, if you are booting from a scsi hard drive, then the bios cannot be set to let any IDE to boot, or the bios must be set to no hard drive to boot. There may be two places in the bios which must be set to no hard drive. Another setting which may make a difference, is the scsi boot setting, if it has it. Another chance is that something is wrong with either the cabling or the controller itself.
As far as the jumper, that may be the erase bios jumper. Usually though, you have to move the jumper to one of two, sometimes three or four jumper. You would simply move the jumper to the erase setting, and then move it back. However, by doing that, you will lose all setting which had been set. Also, if the computer will go past the bios when the controller is removed, that could also mean some thing is wrong with a drive, or the boot drive is not set right in the controller bios. If a scsi drive is a boot drive, that boot drive number must be set right in the bios of the controller.
Our 1600sc dell server is beeping continuosly.
Check the PowerEdge Raid Controller for parity problems. Sounds like the status on the physical volumes participating in a RAID array has been degraded.
Loud beeping from a drive is usually an indication that an invalid drive array member has resulted in a degraded logical volume.
If you were counting correctly, you had at least three drives - most likely participating in a RAID-5 setup. The array might have been rebuilt with one bad drive. But it sounds like you've got two corrupt physical volumes in the array. And that's not good.
Hope you've got a backup!
Jan 19, 2009 | Dell PowerEdge 1600SC Server
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Computers & Internet Logo
866 people viewed this question
Alun Cox
