Question about Philips Nike ACT210 128 MB MP3 Player
Formatting Problem My mp3 player says that it needs to be formatted when I attempt to listen to it or to open it to view its contents. When I try to format it, it does nothing.
  • 102 Answers
That means that the storage on the MP3 Player is corrupt. Replace your MP3 Player.
Posted on May 24, 2007
Will I loose my music if I reset my mp3 player?
Resetting it will not delete files. Files will be deleted when you choose formatting your player option.Based on their manual:
If your player stops responding, reset the player. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring files. 1. Insert and remove a straightened paperclip from the Reset Hole. 2. If this does not work, proceed to Formatting Your Player. Formatting Your Player WARNING: This step deletes all your player's content. If possible, back up all your player's content on your computer before proceeding.
Feb 18, 2011 | Creative Labs ZEN Stone MP3 Player
How do i format my mp3 player without a disk
I don't know if this is affected by the 'network' aspect of your player, but this would be the general procedure for MP3 players, where you can view the player as a drive on your computer.
You can format the player using Windows, but there is a complication: Windows defaults to "NTFS" when formatting, but MP3 players normally use FAT32. Before you attempt this, connect the player, and check the 'properties' on the drive that appears. It will probably say "FAT32". In this case, you can go ahead and format the drive, but be sure that you choose "FAT32" from the drop-down list. If you format it NTFS, your player won't be able to read it!
Jan 20, 2011 | Sony Network Walkman NW-E005 MP3 Player
How to format 8 gig scan disk for mp3
How to format the Sansa View:
To format the player directly, follow these steps:
1. Select More from the Main Menu.
2. Select Settings/Options then System Settings.
3. Scroll down to Format and select it.
4. Select Yes to start formatting.
WARNING: Formatting the player will DELETE all the content you have
on the player.
The player can also be formatted using Windows Explorer or Windows
Media Player.
Dec 25, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Database full, delete content or re-format device
you should format your mp3 and try again.in this way the errors on mp3 player will be removed.
Jun 01, 2009 | Insignia NS-DV2G MP3 Player
Formating my mp3 player
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Jan 08, 2009 | Sony Network Walkman NW-E005 MP3 Player
Mp3 sansa sandisk - deleted songs
Try formatting the drive. Plug it in. Open Windows Explorer. Right click on the drive and select format. This will delete all content off the player.
Aug 31, 2008 | SanDisk Sansa c140 MP3 Player
Won't play (transfer, format, view contents in explorer OK, though...)
Does you player powers on? If no, then you have a problem with the battery pack of your mp3 player. If yes, what file system did you use in formatting your mp3 player? If it's ntfs, try formatting it using fat or fat32. Maybe your mp3 player cannot use the ntfs file system.
Aug 17, 2008 | GPX MW3837 MP3 Player
Sansa m250 not working, need help soon
Plugging it into another computer changed the formatting of the player.. I would format the player from the menu itself, but if that fails:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 26, 2008 | SanDisk Sansa m250 MP3 Player
Problem with my sansa e200
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e200 MP3 Player
T.sonic 610 is not formatting
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Nov 01, 2007 | Transcend T.sonic 610 MP3 Player
Philips Nike ACT210 128 MB MP3 Player Logo
Top Philips Nike Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Philips Nike Audio Player and Recorder Expert? Answer questions, earn points and help others
