Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
CD won't eject (jensen VM9511TS) multi -media player
Each time I try to eject cd in my player it reads briefly then message reads bad disc. I notice that the eject display on screen blinks twice, then it reverts automatically to radio tuner. Need Help!!!
5 Suggested Answers
SOURCE: No video, only sound from tv tuner.
You need to plug the male yellow wire into one of the female wires that says media control...... something along those lines..... youll figure it out
Posted on Oct 11, 2006
hogan doan
  • 227 Answers
SOURCE: jensen vm9511ts wont play mp4 without link
I don't think there is one available yet, you could check the local stereo shops. They would be the first to know. Goodluck.
Posted on Mar 08, 2008
  • 3 Answers
SOURCE: Jensen VM9511TS... Problem
Try a hard reset. If you look on the face of the unit, you will see a little pinhole located on the lower right side, stick a paper clip in there and hold in until the system reboots itself, this should be done while on.
Posted on Apr 01, 2008
  • 15 Answers
ground parking wire
Posted on Apr 10, 2008
hogan doan
  • 227 Answers
Remove the unit and bench test it. Sound like you have a loose power wire. Goodluck.
Posted on Apr 26, 2008
Jensen vm9511ts
Apr 16, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Can you help? Stereo does not take in any discs
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Apr 01, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Will not take in any discs
hogan doan
Jensen VM9511TS : Doesn't take in discs
It sounds like a mechanical error. It's not a quick fix. You (or more likely a repair shop) would have to pull the transport and reallign a bunch of parts and possibly resurface the rollers. It's a GIANT pain in the @$$.
Won't read cd/dvd the unit takes the cd tries to read it and then eject's it.
You either have a bad disc or the lens on the reader assembly is dirty. You can goto Wal-Mart and buy a CD lense cleaner
Dec 13, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen vm9511ts wont play mp4 without link
Oct 01, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
you may have to open the unit up and manually turn the unload and load gear to eject the DVD from the carriage. The load and unload gear is a round gear located under the DVD carriage and is attached to the load and unload motor
Sep 20, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
VM9511TS wont eject
Does it make noises like it's trying to eject? Like whirring motors?
Sep 10, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen vm9311 AM/FM/CD/DVD
you are mising to power on the factory amp.
Apr 25, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Oct 06, 2006 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
35 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
