Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Envelope margin error
When I print a single envelope, it prints fine. When I do a data merge on that same envelope file to print out a series of envelopes, suddenly I get a margin error notice and it cuts off the type on the most right hand side, in this case the "bulk mailing" indecia on the upper right hand corner. No matter how much I pull this type away from the edge of the document, I still get the margin error.
    Scholar:
  • 63 Answers
Have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Posted on Oct 31, 2008
Envelope address is printing at the very top of the envelope, in the center. I've tried adjusting the spacing (# inches from top) in Word under envelopes, but the printing stays in the same spot!
experiment with this
open a new document and type in the address where it would be on an envelope
when you have it in the center of the document go to print and see where it is on the preview
now while in that area click on page margins and move the margins to around what you have on the preview
then set as default
that should mean that what ever is going to be printed will appear in that part of the page or in this case the envelope as the printer and program is set to margins and everything inside those margins will be in the right place
basically it is trial and error but what you want to do is in that section of printing
Mar 02, 2017 | The Office Equipment & Supplies
Trying to center address on 7.875Wx5.5 envelope an run a merge
if you are using word to type the address use the tool bar to center it on the page
then when you go to print , check the preview to see where it will be printed
set the printer properties to envelope and use any old envelope to see where it prints
Nov 15, 2017 | HP DeskJet F380 All-In-One Printer
Won't print envelopes
Envelopes may have to be fed individually through the single sheet feeder
Your word processing software may not have the correct parameters set for printing..
Jan 09, 2014 | HP Officejet Pro 8600 Premium
How do i address envelopes on my lenovo Windows 7 computer
The simplest method of addressing envelopes is to use a word processing application such as Microsoft Word.
If you do not have Word then I would recommend downloading and installing a copy of Kingsoft Office Suite Free 2012 which is compatible with the latest versions of Microsoft Office documents and is free for home users.
Once the application is installed, open Kingsoft Writer 2012 (which is very similar to Microsoft Word).
Click on File then on Page Setup and select the Paper page tab where you can then choose the Paper size to use for your envelopes.
In the Paper size drop down selection listing, choose an envelope size such as C6 Env.
If you are unsure which option to choose, then simply measure the size of the envelopes you are wanting to print on and set the Width and Height values (in centimetres) to match that size.
Next switch back to the Margins page and select the Orientation that you want to use for your envelopes, i.e. Landscape or Portrait.
On this same page you can also increase the Margins to position your address text more centrally on the envelope.
Click on OK to exit Page Setup.
Type your address on the main Kingsoft Writer page and you are ready to print the envelope on your printer.
Kingsoft Writer can also use Mail Merge to write a series of addresses on a stack of envelopes if you need to write a number of addresses.
Simply create a list of your addresses in the Kingsoft Spreadsheets application, putting each 'address field' in a separate 'box' in the new spreadsheet so that you have a column each of 'Names', 'Address line 1', Address line 2, Town, County, Post code etc.
Then in Writer, click on Tools, Mail Merge toolbar, then in the toolbar, click on the left icon to Select Data Source and select your addresses spreadsheet document.
Next, click on the icon for Insert Merge Field and select all the address fields to insert into your new Envelope document.
Finally, adjust the layout of the fields by moving fields on to new lines as needed. You can also change the font and character size of the new address fields to make the text larger or bolder etc.
Last of all, click on the icon for View Merged Data which will show you what your addresses will look like when printed on the envelopes - you can step through the list of addresses using the controls in the toolbar.
Dec 23, 2011 | Lenovo Computers & Internet
NEED TO KNOW HOW TO PRINT MORE THAN 1 ENVELOPE AT A TIME. DO LETTERS AND ENVELOPES ONCE A WEEK BUT THE PRINTER WOULD ONLY PROCESS 1 ENVELOPE AT A TIME AND I HAD TO DO THAT ONE MANUALLY.
Hi there !
For printing bulky letters or documents of the same format, I suggest you use the MS word mail merge document. You need to set up the mail merge document and the data of the file. For examples, the list of names, addresses telephone numbers and others should be input to the envelops.
Here's how to create mail merge document file.
1. Open a new blank MS word document or if you have a format already in a MS word format, just use it as default letter.
2. Go to menu bars (Home, Insert, Page Layout, References, Mailing, Review and View) and choose Mailing.
3. From Mailing, click on select recipients, choose use existing lists and find the excel document files that stores all the information like list of customers, company names, addresses, telephone numbers and others.
4. Open it and select table will appear and just click ok to merge it automatically to your default envelope.
5. Now you need to set up or format your envelope. from the Mailing menu, Insert Mail Merge Field will appear and click it to display the headings of your data source. Put the headings wherever you want.
6. After that, press preview result to display the datas. Save your work and it is finished
7
Jan 06, 2011 | Lexmark X 546dtn AllInOne Laser Printer
My HP officejet L7680 prints #10 envelopes differently from the intended design. It moves the logo and return address lines to an unwanted location on the envelope face. How can I fix this?
Please consult this HP support article for printing envelopes with your machine. Make sure you have allowed a sufficient margin from the edge of the envelope or the printer will be unable to print your setup. If you're using a MAC os, see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Oct 09, 2009 | Office Equipment & Supplies
Bulk mail inde
Put spaces in your type to move it over if you cannot move the margins. You might also be able in print options page setup to indent the margins or paragraph so it prints inside the page.
Aug 31, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do you print envelopes?
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007. From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
Jul 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Envolpe feed problem
I would first off try cleaning the feed roll in that tray well. That really sounds like slipping.
Go through all your programs and make sure that the driver machine and program you are running has the envelope settings the same.
Be sure they all match. Example. Make sure all the programs you are running through, have the settings for # 10 envelope, consistancy is needed for running envelopes. They are problematic.
May 01, 2008 | Xerox Phaser 8500/DN Printer
Mail Merge Print Problem
Was a recipient address created in an Excel spreadsheet or a database? Data needs to be pulled from somehwere to be added to the envelope.
Dec 05, 2007 | Dell Latitude D800 Notebook
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
229 people viewed this question
Ben Johnson
