Question about Mesh 80mm Aluminum Fan Filter Fan Kit
Compaq Presario SR1365CL (4) yrs old, fan making annoying noice
My compaq presario (4) yrs old SR1365CL has started to make an annoying humming sound. The noise gets louder the longer it stays on. I think it's the fan. Is this something minor that can be resolved? Need computer for business, cannot afford to replacecomputer at this time.
Thank you,
dstep
  • dstep6 Oct 20, 2008
    Thank you, I will try your suggesion.
    Master:
  • 788 Answers
Often you can blow the dust out of the fans and it will help. In your case the bearings have most likely dried up on a fan. First blow the dust out of all the fans. To find the offending fan you will have to block the blades with something. Once the fan is found you can either replace it with a fan of the same size or re-oil the bearings. To re-oil, carefully peal away the label on the fan. There might be a plastic plug over the bearing, carefully remove it. Drop a few drops of 4-in-1 oil or sewing machine oil into the bearing. Stick the label back on and put the fan back into the system. It should be much quieter now.
Posted on Oct 20, 2008
Bios rom checksum error on a compaq presario SR1365CL
This is a typical sign that the CMOS battery (on the motherboard) has failed & needs to be replaced. After replacing the CMOS battery, you will need to boot into BIOS & save CMOS settings.
Jul 13, 2011 | Computers & Internet
Compaq presario sr1420nx fan noise
Just replace the fan. They are a standard commodity and not hard to change. Get a good one this time. You get what you pay for.
Feb 14, 2008 | HP Compaq Presario SR1420nx...
The fan on my compaq presario is running all the time I have to reboot to get it to stop
Sign in to get personalized recommendations. New customer? Start here. ... This review is from: Compaq Presario SR2170NX Desktop PC (Intel Pentium 4 Processor .... It DOES have a Pentium 4 though which can run hot so the fan will kick on for a ... most of my software. I don't have time for POS computers like this. ...
www.amazon.com/Presario-SR2170NX-Desktop.../B000M8MWHO
Jul 11, 2010 | HP Compaq Presario SR2150NX PC Desktop
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
Fan constantly running,have comp presario sr1420nx about 4 yrs
If blowing the dust did not help your only other options are replace the fan or replace the heat sink with a newer one that incorporates a quieter fan.
Jun 09, 2009 | HP Compaq Presario SR1420nx...
Desktop Fan "surges" in and out.
Chazzl,
Probably the desktop fan, a quick way to test for sure is to stop the fan with you finger when it is making the noise.
Just place your finger lightly in the middle of the fan and check if the noise stops.
Dont leave your finger there for more than a couple of seconds and mind the blades as it does smart a bit if you catch them.
Good luck
Nick
Oct 27, 2008 | Compaq Presario 5000 PC Desktop
Noices
there are two fans the heatsink fan and an extractor fan, either of theses can be replaced, you buy the heatsink and fan together for the processor and a seperate case fan can be fitted easily by yourself
Nov 06, 2007 | HP Compaq Presario SR2150NX PC Desktop
Computers & Internet Logo
230 people viewed this question
Top Mesh Computers & Internet Experts
Sandeep Kumar
steve s
steve s
Glyn
Are you a Mesh Computer and Internet Expert? Answer questions, earn points and help others
