Question about Dell A920 InkJet Printer
Driver for vista
I change my PC. New PC is Windows Vista, and I cant install Driver to
printer A920.
  • 31 Answers
Quoting Whitetiger on this.
I hope its ok tiger, i just read a similar problem solved by you.
Quote from Whitetiger:
"**UNISTALL ANY DRIVERS YOU HAVE INSTALLED FOR THE A920
YOU WANT A CLEAN INSTALL
Go to Control Panel -- find your printer and uninstall
or
Uninstall the Existing Dell All-In-One Printer Drivers
  1. Click Start, point to Programs, point to Dell, then click Dell Printer Software Uninstall.
  2. Select the components to uninstall, and then click Next.
  3. Click Uninstall Now to proceed with the uninstallation of the printer drivers.
  4. Click OK after the uninstallation has been completed.
BEFORE YOU GO TO ANY DIRECTIONS BELOW---
IF YOU ARE RUNNING VISTA GO TO www.dell.com
At the top right side Search box type in the Journal Number
Journal ID: 08088J5HPH Article ID: 317175 Date Published: 2/19/2008 Last Revised: 3/17/2008
This will take you to a Page Printer Driver Communication Errors in Microsfot Windows Vistadriver for vista - mag-glass_10x10.gif
Follow the instructions on the this page.
Printer Drivers for Vista are different than XP
For Vista you need Driver R153716.exe
and then you have a Patch R166244.zip
First you install the driver
then the patch
Specs for your computer
http://support.dell.com/support/edocs/systems/ins1501/multlang/dao_emea1/TM686am2MR.pdf
This is a wired printer, not a wireless printer, so it must be connected to the laptop.
  • There are up to three ways to set up your printer. You will need one of these three cables: USB, RJ-45, or parallel.
Next step
The cable you use connects to the computer
Next step
  • Turn your PC on, if it isn’t already.
  • Connect the cable you are using to the back of your computer or server here.
  • Next step
    • If the "Found New Hardware" wizard pops up on your screen, close it.
    Next step
    • Make sure paper is in the paper feed tray and the paper extender at the top is fully extended.
    Next step
    • Insert the software CD that came with your printer.
    driver for vista - 3100_3_8.jpgt step
    • The software should auto-run on your computer. If not, choose My Computer and navigate to the optical drive to start the software yourself.
    • Follow the instructions in the software and click OK and Next when prompted.
    • driver for vista - 3100_3_9.jpg/span> Next step
      • Print a test page to see how your printer is doing.
      Now please read this:
      After everything above is done, MAKE SURE THE PRINTER IS ON!!!
      If you are running XP or Vista
      Click Start
      Right click Computer
      Click Properties
      Click Device Manager
      In the Device Manager make sure you do not see any yellow ! points
      Now in the Device Manager
      click on Imaging Devices---do you see your printer; IT SHOULD SHOW THE PRINTER NAME
      Now click the Portable Devices
      Do you see the printer ---- IT SHOULD SHOW THE PRINTER NAME
      THIS MEANS THE DRIVERS LOADED ---NOW CLOSE THE DEVICE MANAGER
      For all intense and purposes, if you loaded the right drivers, the printer should run fine.
      One other thing you can do is run Windows updates to see if it sends you any updates for your printer----
      In XP click custom
      In Vista it will automatically show you all the updates
      Any more questions, contact me.
      Please rate this advice. Thanks so much!"
    Posted on Oct 20, 2008
    • 21 Answers
    3 Suggested Answers
    mrlobsterbob
    • 22 Answers
    SOURCE: Dell A920 with Windows Vista
    see if you can get a driver from dell web page that works with vista
    Posted on Feb 22, 2008
    I downloaded R153047.EXE from Dell's website and installed it. After doing that I can now print from Windows Vista Ultimate (it solved the "cannot communicate" problem). However the buttons on the printer STILL do not work to bring up the All-in-Once Center software. I can scan using "Windows Scan and Fax" and it works fine. The only problem seems to be the All-in-One Center software that doesn't work therefore causing the printer buttons to do nothing.
    It isn't great but that's how I got it to work. Hope this helps.
    Sorry I didn't post a link directly to the file, but I already closed the browser window where it was. :)
    Posted on May 18, 2008
    Is there a windows 7 driver for the A920
    First run Delete Print Jobs to remove any stuck print job in the queue.
    Disconnect the printer.
    Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
    Restart your computer. Make sure the printer is removed.
    Manual Printer Driver Removal
    Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
    Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
    Links to the patch/drivers can be found at...
    Dell A920 All-In-One Inkjet Printer owners thread (W7)
    Remember virus programs and firewalls will block communications.
    Rick
    Oct 19, 2011 | Dell A920 InkJet Printer
    I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
    First run Delete Print Jobs to remove any stuck print jobs in the queue.
    Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
    Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
    Virus programs and firewalls will block communications.
    Rick
    Apr 18, 2011 | Dell A920 InkJet Printer
    My dell a920 printer won't print with windows 7
    Hi There
    Not no if you may have the wrong driver, this one is for Vista and most Vista drivers will work on Windows 7 gave it a go.
    I have put a driver for you on my website for you it for windows Vista to download just click on the driver link and it will download for you, best to save it to your desktop so you can find it.
    Link = http://www.4all2sell.com/driver/Dell-A920-Vista.exe
    After you have downloaded it just double click on the icon Dell-A920-Vista.exe and follow the instructions to run the.
    Please call back to say if it works for you Thanks
    All The Best: Pineworks
    Feb 11, 2010 | Dell A920 InkJet Printer
    Hi!
    That A920 is working with vista, here is the drivers for thet:
    http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A920&hidos=WW1&hidlang=en&TabIndex=
    Dont forget to download and install the application to, you need all the files on that site
    For that 968 printer, uninstall it, download the files from the link below and reinstall it, that will make your printer work again
    http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A968&hidos=WNT5&hidlang=en&TabIndex=
    Let me know how it goes
    Good luck
    Nic
    Mar 30, 2009 | Office Equipment & Supplies
    For a Dell A920 (Personal All-in-One), pls download OS appropriate driver(s) from here. Pls select Vista, thereafter, install.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    Aug 21, 2008 | Dell A920 InkJet Printer
    Feb 22, 2008 | Dell A940 All-In-One InkJet Printer
    Driver for vista windows
    Hi Ashford,
    I search the driver or your printer, i copy and paste it here.
    Just click on the link below to download the driver:
    PRINTER DRIVER VISTA only
    Enjoy
    Hope's it works!
    tnx
    -micro
    Feb 10, 2008 | Dell A920 InkJet Printer
    Believe it or not... the driver is buried on the Dell site for Vista 64-bit. I search and searched ... and there it was.
    http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R153048&formatcnt=1&libid=0&fileid=203948
    In any case, I downloaded it, installed it, and it works fine. All the buttons (scan/copy) on the top work as well as printing. Now if I could just get my old XP machines to print to it on the network. But.. I think that is another thread.
    Oct 27, 2007 | Dell A920 InkJet Printer
    Dell A920 InkJet Printer Logo
    88 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
