Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba MW27F51 Do anyone know why my TV/DVD/VCR shows black and white only when you are watching DVD.I clean the laser but still the same.
  • 1,476 Answers
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
Posted on Jul 13, 2006
Recently bought a toshiba tv and dvd combi but wont play any dvds
You need to go in the menu and change the region code. yours is not set for amarican made dvd's
Mar 05, 2013 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
THE DVD WON'T OPEN OR PLAY ON MY TOSHIBA TV/VCR/DVD COMBO MW27FN1
check either the front or back of television for a small pinhole, that should be the emergency eject hole, place unwound paper clip in hole to eject disk, however, this will probably be re-occuring and dvd player will need to be replaced.
Oct 17, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
MY toshiba tv MW27F11C only shows a white line when turned on
Hello uuka,
You have vertical collapse. This is most often caused by a defective vertical output integrated circuit, an open dropping resistor which feeds the supply voltage to the I.C., one or more defective electrolytic capacitors in the vertical circuit or something as simple as bad solder connections. The latter will usually manifest itself as an intermittent failure. Less likely, but stilla possibility is a defective yoke, but this a rare.
Unless you are handy with a soldering iron and have some experience this is definitely something I suggest that you refer to a qualified technician. Depending on the actual cure for the problem, this would typically be under $100 in my shop, but we are in a small town and prices are cheap. I would definitely recommend a repair on this since it can not be replaced. They don't make a TV/DVD/VCR combination any longer and the picture quality on these Toshiba/Orion combos has been very good over time.
Hope this helped and don't forget to rate...
Thanks!
The Wing Guy
Apr 29, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
I have a Toshiba TV/DVD/VCR combo model # MW27F51-had it for a couple of years. Turned it on, have sound but no picture. I have the cover off the back of it now.
sound like a defective part inside the set. i could tell you what one went bad, this is not user servicable, and could shock you bad. i would take it for service or get a new one. due to the cost of these against the cost of repair.rule of electronics-if the cost of repair is 60% of a new one you should not repair it. good luck! hope this helps!
Feb 27, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Straight line
You need to replace the vertical output transistor. part are available online at www.digikey.com
Aug 24, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba Remote
you can buy a universal remote if the cost of a replacement is too high. hope this helps, good luck.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Tv toshiba vertical problem
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Jan 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Quasar tv/vcr combo vv2009
clean the head of your vcr if that does not work then you will have to call in the tech to look into your problems goood luck.it is probably the color circuit
Apr 28, 2007 | Quasar VV2009 Combo
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
299 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
