Question about Wilson Dual-Band Glass Mount Antenna 301102
Need mast for Wilson 301102 glass mount antenna
Looking for a replacement mast for my wilson 301102 glass mount antenna. Wilson says they won't sell the mast separately. Know where I might get one or another brand that will fit and work with Wilson mount? Thanks in advance. -Winston
2 Suggested Answers
SOURCE: Need assembly instructions for a 10x12 Wilson
I looked for hours on the internet trying to find this.
Hope this saves you some time. The manual can be downloaded here.
You can show your appreciation by becoming my scribd follower so you can get all my do it yourself posts.
http://www.scribd.com/doc/55393964/Monterey-Gazebo
thanks
Bill Kibbe
Posted on May 13, 2011
Grease under the Coil of a Wilson 1000 CB antenna
Animal greases and Metal grease will conduct electricity. I use silicone grease for my receiving antennas.
Nov 24, 2013 | Wilson Antenna Wilson 880-900802B W-1000...
-wilson antenna installation diagrams for, Wilson Trucker2000 - display pictures of exactly, how antennas appear when being attached with coax cable, using stud mount between coax & antenna mount... -...
I have a wilson 5000 mirror mount. I mount it on the drivers side mirror on the upper cross arm that goes to the mirror. It is mounted on this arm with a bracket and a so 239 connector so I can undo it if I have to ,leaving the antenna connected.I can change coax and not have to worry about undoing the antenna. Remember one thing. The antenna has to be checked for SWR.each time you move it to a different spot or to a different truck.
Oct 11, 2011 | Cobra 29 LTD CB Radio
I have uniden cb and I can't get the pa to work it just play the weather and my antenna is broken if it has anything to do with it
Hi, my name is John. Some twenty-three channel radios have the PA located between channel twenty-two (22) and channel twenty three (23). Make sure you have the right PA plug for it, as far as the antenna, get you a good one, say a Wilson 1000 or a Wilson 2000, they are great antennas, magnet mount. You need to press the PA button. Hope this was helpful...Rate this solution on the four thumbs-up. .Good luck John.
Oct 03, 2010 | Radio Communications
Cb radio
As for me ,the Wilson 1000 or Wilson 2000 are the best mobile antenna for a mobile. I have out talked a lot of base antennas with them, just put it on the top of car in the center or trunk, or middle of cab of truck, with a good SWR and you are talking and receiving. great antenna. ...hope this helps..
Jun 01, 2010 | Cobra 29 LTD CB Radio
White boy here, i'm installing a connex 4600tinto my 4runner and need to know how big of a power wire to use and proper way to put my wilson 5000 in ground wire ect. thx
you can use 8 gauge wire, this is only 190 watt radio, do put a fuse in line close to the battery. Wilson 5000.....wher are you going to mount this..I'm guessing that this is the trucker series antenna. You do know that the load has to be at the top of the roof? Again how and where are you mounting the antenna?
Jan 19, 2010 | NorthPoint NP-9-HP Base CB Radio
Setting SWR Wilson 5000 magnetic mount antenna. Started with a reading over 10, reduced it to just under 7 by reducing the hight of the whip, should I check the pl259 connector and check the coax for...
Your antenna is probably still to long. You need to do a few things to see if your antenna is too long or too short. Here is a link to something I found that is very informative, and a post on how to do what you need to do. there is also a thread on the site that has common problems for high swr.
http://cbmx.org/forum/showthread.php?t=8
here is common problems for SWR
http://cbmx.org/forum/showthread.php?t=46
Start with the first article.
Sep 21, 2009 | Wilson Dual-Band Glass Mount Antenna...
Calibration problem
Changing the length of the mast more then likely made your antenna to short, and therefore impossible to tune.
Jul 01, 2009 | Cobra 29 LTD CB Radio
Maximize my cobra18 WT ST
A good antenna goes along way for your transmit distants. It does close to 90% of the work on that side of things, but also remember that the radio itself does most of the recieveing. I good antenna brand to stick with is Wilson they make several units but for you a Wilson Little Wil would do the trick. There not real tall about 3' and cost around $40.00. If you want more performance a Wilson 1000 Mag mount is one of the highest performance antenna's on the market but its tall around 5' and cost somewhere around 80.00-90.00 . You can tune the radio and get alittle more out of it but not much, get a good antenna and go from there you will like it. Dont forget that any antenna has to be tuned (swr set) to the vehicle this will insure max performance.
Jun 24, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Nov 18, 2008 | Connex 3300 240-Channels Base CB Radio
Wilson Dual-Band Glass Mount Antenna 301102 Logo
29 people viewed this question
Top Wilson Car Audio & Video Experts
xxxxxx xxx
Are you a Wilson Car Audio and Video Expert? Answer questions, earn points and help others
