Question about Microsoft Office Professional 2007 Full Version for PC
Need a control/button in Access 2007to open another document
I am creating a database for work. I am hoping to create a button/control in access that will take a person to the correct Word/excel documents that needs to be completed and printed off for the client. At this time I do not eant to create a merge documet, but that will be coming later. Now I jsut need to get access to open the word or excel document. Can access do this? And if yes, how do I set it up?
  • 1,605 Answers
Yes it can be done, however, it is not some thing can be done with this service.
if you need to know how, please email me at
I do need to see the access that you have created in order to do what you need to create.
Posted on Oct 20, 2008
Access 2007 corrupted database
You may try this third party tool programmed with best technology the tool support all windows and MS office versions. You may try free demo version of this software to preview your recovered access database. SysTools Access Recovery you may check How tool works and its user friendly interface make this easy to handle.
Jan 11, 2015 | Microsoft Office Professional 2007 Full...
You'll need to instantiate (create an instance of, or an item in memory) what is known as an ODBC connector. You will also need to create a database or have a database to work with - Microsoft Access will work fine for this, alternatively you can use OpenOffice's version of Access.
The code you'll want to use will be approximately
Dim ws as Workspace dim db as database dim strConnection as string set ws=DBEngine.Workspaces(0) let strConnection= "ODBC;DSN=" & DatabaseName & ";UID=" & UserName & ";PWD=" & UserPassword set db=ws.OpenDatabase("", False, False, strConnection)
Apr 07, 2011 | Microsoft Windows XP Professional
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 ( ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 ( ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Oct 16, 2009 | Microsoft Access 2003 for PC
Problem opening Access Database-upgrade from Access 2003 to 2007
It seems that you have your Database(.mdb) file is created in Office 2003.... thats why you are unable to open it in 2007.... I faced the same problem.... then I came back to 2003 in order to use our database......
Mar 25, 2009 | Enfocus PitStop Professional 08 Full...
have to follow few steps.
1. new database - give any name
--> design table
e.g id, name and file (the datatype of the file should be hyperlink other wise it wont work)
--> enter some records (in file field write a, b ,c)
--> when you put record in file field then click on hyperlink option on top.. (like first record id=1, name=fahad, file=A) select the A and click on hyperlink option on top and give the hyperlink of the pdf file
--> design the form
--> run the form
--> click on desired file
--> it will open
--> looks complicated but its easy
it will work definitely
Mar 24, 2009 | Microsoft Access 2003 for PC
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
Mar 13, 2009 | HP Computers & Internet
How do copy a table from an access database in one folder to another access database in another folder through visual basic code
Simple method Open both tables (or create second) and copy each record from source to target through 'do while not eof' or 'for each' syntax.
Second solution create link in target DB for first table, and use SELECT INTO statment in SQL.
Mar 02, 2009 | Microsoft Visual Basic 6.0 for PC
How to create a program using ms access?
you need to study the basics of database programming. take short courses for database programming.
Dec 04, 2008 | Microsoft Access 2002 for PC
How to create database in
you can create static data base in Excel works heet and link each cell to another sheet.
or you can create a dynamic data base in access. you need a MS access book. there are lots link you need to understand in order to have a working data base.
Nov 28, 2008 | Microsoft Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
