Question about Kenmore 62702 Microwave Oven
Kenmore micriwave won't heat!
I have a kenmore over the stove microwave M/N363.67202 purchased in 2003, just started not heating food. the turntable moves and panel seem to be working. What suggestions do you have of part is broken, as I am a technician and not afraid to get in there and fix.
Thanks
  • 3 more comments
  • Anonymous Nov 16, 2008
    I have the same problem . Thanks for writing your problem . It may solve my microwave issues.
  • eaarnold Dec 10, 2008
    kenmore model #721.63252301
  • Anonymous Dec 25, 2008
    I have the same problem. model number is 363.62702200
  • jammons Feb 25, 2009
    Obviously there's a pattern here!
    My Model 323.62702200 Kenmore microwave has just this morning stopped heating as well.
    Thanks for the tips on how to troubleshoot the problem!
  • Anonymous Mar 28, 2009
    Kenmore 721.623252301 model has just stoped heating things up.
  • Kenmore Master
  • 9,086 Answers
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Your biggest suspects will be a bad connection or relay on the control panel, a bad connection on the magnetron terminals, a bad magnetron, a shorted high voltage rectifier diode or a bad high voltage transformer.
You can find exploded views and part numbers by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You may be able to find better part prices than Sears here.
Your magnetron may have a 5-9 year warranty, so check your manual for that. Sears may send you a magnetron if it's bad and warranty.
Posted on Oct 23, 2008
The two heat rod is heating but the waves is not working if i keep a glass of water its not heating in a microwave possition
Posted on Apr 06, 2011
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
Microwave won't heat food
9 out of 10 times if all else is working then it is the magnatron rod that does the heating chances are it will be more expensive than to purchase a new microwave.
Feb 14, 2013 | Microwave Ovens
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
Tray is not rotating when the microwave is operating?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101--=
Jul 16, 2010 | Whirlpool MH1150XM Convection/Microwave...
I have a ge built in microwave model # JK90BM2BB but won't heat
This is a sure sign that the MAGNATRON has burnt out and needs replaced! (If the turntable works and the control panal is still working)! The MAGNATRON is what cooks the food)
Please rate my quick response!
THANK You!
Jan 16, 2009 | Kenmore 62622 Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Kenmore 62702 Microwave Oven Logo
715 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
