Question about Creative Labs Zen V MP3 Player
Creative zen frozen
I have read all about holding down the pla/pause while putting paper clip into the reset button. Question is: where is the reset button. I don't see anythign that looks like a reset button. There is a very tiny rectangular slot next to the memory card place, is that is?
Thanking you in advance,
jan
Yes, the reset button is in a hole on the side with no lable or any other oraphis by it. If you still have problems with it freezing, try reformatting or cleaning your player (but this will erase everything on it). To do so, hold down the PLAY button while turning your zen on. When your first screen shows up (creative) hit the play button again. This should bring you to a recovery mode screen where you can manage certain tasks that may help your cause...Remember, reformating will erase EVERYTHING!! But I'm shure if you're taking it this far it's worth the trouble.
Posted on Nov 06, 2008
There are actually two slots. one is a microphone and the other is the reset. Make sure it does not have a picture of a mic next to it before inserting paper clip.
Posted on Oct 22, 2008
The screen says "Docked, please wait". It says
When this happened to me with my Zez I was able to reset it by pushing the reset button (located in a little hole next to the dock on the bottom of the unit) with a straightened paper clip or other small object capable of fitting in the hole for a few seconds until the unit fully resets.
If that doesn't work you can try putting the unit in to recovery mode to reset it by doing this:
  1. Detach the Zen Sleek player from your computer, and ensure that the unit off.
  2. Connect the power supply to the player (Optional, unless the battery is very low).
  3. Hold down the Play/Pause button, and then insert a paper clip into the Reset hole underneath your player, beside the data/power connector. reset_sleek.jpg
  4. Remove the paper clip from the Reset hole. The Rescue Mode screen will then appear.
  5. After the recovery mode has started, release the Play/Pause button
Mar 05, 2011 | Creative Labs Zen Sleek Photo MP3 Player
My mp3 touch screen froze while i was useing it
1. Connect the player to the mains via the power cable.
2. Straighten out a paper clip.
3. Hold down the Play/Pause button, and poke the paperclip through the reset hole (still holding down the play/pause button)
4. This will acces the recovery mode. Scroll down and go to reboot. Press the OK button.
I can't remember if this resets the data though?
But once you have control of the zen head on over to their website and update the firmware (this will wipe all of your songs, but would you rather have an MP3 player with music you cant listen to?) Haha
Anyhow hope this helps.
Aug 23, 2010 | Creative Labs Zen Touch MP3 Player
Creative Zen frozen and Reset has not worked
You probably shouldnt play with any of the buttons really but i know how to fix it. You hold down the slide power for about 5 seconds and poke the reset button with a pen tip or w.e for about another 5 seconds till it restarts itself.
Mar 28, 2009 | Creative Labs Zen Digital Media Player
My Creative Zen Touch is frozen. When I hold down the "Menu" button, the screen does not change. When I connect to the computer and attempt to run Creative Mediasource Organizer, I get a message that the...
I would run the recovery console from the player itself. Make sure the Touch's power supply is plugged in (and unplugged from a PC) then to access the recovery mode of the Touch, hold down the Play/Pause button while inserting a straightened paper clip into the reset hole on your player, give it about five seconds then remove the paper clip.
Next, keep on holding the Play/Pause button until the Rescue Mode screen appears. After you see the rescue mode menu, you can release the play/pause button.
I would try a "clean up" first, as this is less intrusive and will not erase data.
Mar 27, 2009 | Creative Labs Zen Touch MP3 Player
Frozen
There is a small pin hole reset button, you will need a small pin to push the button on the inside, hold the button for about 20 seconds.
Dec 29, 2008 | Creative Labs Zen Touch MP3 Player
My Zen is frozen...
push a paper clip into reset hole!!
Jul 17, 2008 | Creative Labs ZEN Vision:M Digital Media...
Help
I just got done fixing my daughter's Zen V 1GB which was frozen by holding down and keeping the play/pause button pressed and then powering it up. This will put the unit into recovery mode.
I selected "Clean Up" and this fixed the problem. I will assume the other options are a little more destructive to the stuff you've uploaded to it. Hope this helps!
Apr 20, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Touch Harddisk Problem
was the unit dropped?
is the unit out of warranty?
if yes to both of these then you need to replace the drive
some have replaced with flash drives
I found this. *Plug the Creative Zen in to the charger and plug it in the wall. *Press in the Play/Pause (same button) and hold it in. *Insert a paper clip in to the pin hole on the left side of player, near the bottom. *Hold the needle or paper clip in for 4 seconds and let go. *Keep holding down the Play/Pause botton. What I did was clean up disk. Then Reboot.
Dec 11, 2007 | Creative Labs Zen Touch MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative zen touch (DAP-HDDD14)
There is a liitle hole down one side of your player. Put a straightened paper clip into it and it will reset.
Nov 16, 2007 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen V MP3 Player Logo
76 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
