Question about Garmin nuvi 200W GPS Receiver
Removing unwanted vehicle icons
Hi
How can I safely remove unwanted vehicle icons in maps , & vehicles on a Garmin nuvi 200 W ??
thanks
  • Garmin Master
  • 2,130 Answers
Connect your Nuvi to your PC via USB. When your PC recognizes the Nuvi, select the Nuvi using windows explorer and click on the Garmin directory within your Nuvi. You should find a folder called "vehicles". Click on that folder and you should see the vehicle files. Just click on the one you want to remove and then right-click and select delete.
- Jim
Posted on Oct 21, 2008
I have a Garmin Nuvi 205W and have saved a number of places as favourites. However, when I want to share the location with friends by giving them the map coordinates of these places I cannot find how to...
To view the coordinates of a saved location on your nuvi
  1. Touch Tools (wrench icon)
  2. Touch Settings
  3. Touch System
  4. Turn ON the GPS Simulator
  5. Touch OK
  6. Hold Back to return to the main menu
  7. Touch Where To?
  8. Touch Favorites
  9. Select a favorite location
  10. Touch Show Map
  11. Touch Set Location
  12. Hold Back to return to the main menu
  13. Touch Tools1
  14. Select Where Am I
Here you will see the coordinates for the saved location.
1. For nuvi 200 series units that do not have the Where Am I feature, skip the above steps 13-14. The coordinates can be found by pressing the vehicle icon on the View Map page.
Instructions on Backing up and restoring Favourites can be found at
http://www.garmin.com/garmin/cms/cache/offonce/us/support/searchsupport;jsessionid=72CF55C22FEF1BA5AA08FFCAC89B9E59
Aug 12, 2010 | Garmin nuvi 205W GPS Receiver
I can't get an update on my nuvi gps 200 for maps, even the map of Mexico.
the Nuvi 200 has an extremely small memory, less than 1gb. The US maps for the nuvi 200 only include the lower 48 for that reason. Not sure how large the map file is for Mexico but your only safe option is to contact Garmin direct.
Jan 11, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 260W will not start up. When not conneccted to power, unit attempts to start up, shows Garmin logo, then copyright logo, then "loading maps", then goes blank. When connected to power, the unit...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu. clip_image001.jpg clip_image002.jpg
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
Jan 09, 2010 | Garmin Nuvi 660 GPS Receiver
While using my Garmin Nuvi 205W for navigation I plugged it into my car charger and the screen changed to GARMIN with a computer on the bottom, like it was plugged into a USB port. Can I charge my Nuvi...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First make sure you have a Garmin CHARGER.
Notes:
  3. Then Make
    SURE:
  4. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
    After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
    REMEMBER: It takes hours to do a complete a map update.
    Unless you bought the Lifetime maps you may have to pay for current maps.
    Does this help? Let us know. Thanks.
Oct 18, 2009 | Garmin nuvi 205 GPS Receiver
USA Garmin nuvi 200. Can I download Ireland map?
You will have to buy a version of European maps. After you download them into your Garmin it will work just like in the US.
Here is a link I found for you. It looks like you need to buy all of Europe but there may be a way to just buy individual countries. Best wishes on your trip.
Wide and way cool, nüvi 200W shows you the way with detailed maps on a bright ... Garmin Garage" vehicles compatible (download car-shaped icons to your device ): yes ... nuvi 200W, Eastern Europe, 010-00656-25. nüvi 200W, Italy, Greece ...
https://buy.garmin.com/shop/shop.do?pID=9122
Aug 17, 2009 | Garmin nuvi® 200 Car GPS Receiver
Missing system software
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
May 17, 2009 | Garmin nuvi 200 Car GPS Receiver
Vehicle icon next to road on map
Some SatNavs / GPS units have a 'lock to road' option. Go through the manuals / screen menus to see if it has that option and set it on.
HTH
Peter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 250w adding new cars
Icons of vehicles must be in\Garmin\Vehicle\ folder as a *.srt files.
Then go to Settings\Map\Vehicle-Change, depress Up/Down arrows, select vehicle on the left, depress it icon and OK. Now you must see icon on the map on the right. Then go back.
Oct 02, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 200 -- won't power up after plugging into USB & Computer
Found out from Garmin Tech services how to reset the NUVI. Good to go.
Thanks.
Aug 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin nuvi 200w map update 2009
Delete all the vehicles and voices that you don't use as well.
Btw, beware that the "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" for nuvi 200/205 is BUSTED, it probably will not work (I just spent 2+hrs on the phone with garmin tech support to fix it.) Search these forums for "nuvi 205 no detailed maps" for more details.
Jun 17, 2008 | GPS
Garmin nuvi 200W GPS Receiver Logo
413 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
