Question about Magix Music Maker 12 Deluxe
Not recording on sync witht the beat
When i record its not on the same timing as the beat. Like its late or somthing...please help
  • Anonymous Dec 06, 2008
    Every time i try 2 record to its off beat two but wat i figured out is if u put no grid instead of 1/4 note you can move it to the right position
  • Mrprovmrong Mar 05, 2009
    When i hit a key on my keybord it send the signal late to the recorder please help
Some of the Magic products just don't work well with Vista. Try setting you compatibility settings to xp using the compatibility wizard.
Posted on Jan 25, 2009
This is due to LATENCY - check the help index on whatever program you're running, they may give a way to minimize this. The software takes the MIDI info (when you hit a key), and runs a zillion calculations to arrive at the sound you hear at the end, but this takes time. It also depends on how good your sound card is.
Posted on May 16, 2009
I recorded drums to the internal click track/metronome and drums are in time with metronome when i play it back with the click from the start of the song. BUT, if i stop in the middle of the song and...
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
Jul 01, 2011 | Tascam 2488mkii 24 Track Recording...
All my vocals are recording late oner my tracks how do i fix that?
you need to make sure that you are using the M-Audio sync and not your sound card to sync voice. I guess you could use your sound card but make sure your instruments are using that sync too. most sound cards don't do well at recording audio in an environment that includes instruments being recorded at the same time.. If you mic has line in or instrument in, use it instead of sound card to record your instrument.
If what you are doing is singing along to a sound track then use the same sync for both.
Mar 17, 2011 | M-Audio Producer USB Microphone with...
I dont know whats wrg but when i record its like 1/2 a second late. making the recording off beat.
I use to own a cakewalk, LOl. Mine did that too. After recording you have to align them on the computer. This happens because the sound takes time to process, and by the time it reach the computer it is already a bit behind. You cant fix that. The only thing you can do is correct it by editing. With a little practice you can align them perfectly. Have fun recording.
Aug 15, 2009 | Cakewalk Home Studio 7 XL Full Version for...
Recording with sony acid 6.0
my vocals are off beat when i record why is that.
Mar 29, 2009 | Sony ACID Pro 5 for PC
Timing problem!! help needed badly!
Your solution is to delay or speed up the sound that your running thru to your computer. The reason why they put user recording latency under the options then preferences then audio settings is not because this never happens or isn't know about. If your sound is too late in the track you have to re-record the track with a higher number try about 125-160. A hint is to play some notes to the beat, check to see that you are in time, then record what you are planning to record.
Jan 11, 2009 | Sony ACID Pro 5 for PC
Tracks get out of sinc when recording on Magix Music Studio Generation 6
could you explain this more in detail.
what are you exactly trying to do and what is the problem.
also let us know the steps taken by you till now to correct the problem
Sep 06, 2008 | Audio Players & Recorders
Recording Late
Check your automatic clock setting. If it is on automatic, set it to manual, and set the date and time on the recorder. It may be picking up an unreliable time setting from a station that is not too accurate.
tom
Aug 26, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Cant record vocals while listening to beat without the beat being recorded twice
i have the same probelm as da 1st guy,, when i record my vocals some how da beat sneaks into da mic too and fuccs it up.. seriously its ****
Jun 23, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. stacy_sunshine_t@yahoo.com if anyone can help.
Sep 17, 2007 | Panasonic DMRES15 DVD Recorder
Magix Music Maker 12 Deluxe Logo
203 people viewed this question
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
