Question about Logitech Z-5300 Computer Speakers
How to use Logitech Z-5300 Computer Speakers without the remote
I have Logitech Z-5300 Computer Speakers but remote is missing. So, can I use it without the remote and what should I do. Thanks
  • 1 more comment
  • Anonymous Jan 05, 2009
    Remote lost, need mod to bypass the remote and run direct
  • nu14u2njoy Mar 23, 2009
    no remote either!!
  • phillzz Apr 18, 2009
    My remote is death, what can i do?
3 Suggested Answers
  • 38 Answers
SOURCE: Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
Posted on Mar 04, 2008
garydillon
  • 42 Answers
SOURCE: no sounds on my speakers
1. Power to the speakers (make sure they are plugged in!)
2. Make sure the speaker line is plugged into the correct port on your sound card. The connector should be green and possible the port will be green to.
3. Double click the little speaker in the bottom right of the screen (assuming you are using XP/VISTA) and make sure nothing is muted.
Post back with your results.
Posted on Jun 03, 2009
  • 60 Answers
SOURCE: Logitech Z-5300 Turns off and on by itself
Try unplugging it, turning off your computer, and plugging it back in.
If that doesn't work, try installing new drivers.
Posted on Sep 19, 2009
We connected our z 5300 speaker to a new computer. and get no. sound. Is there a driver that needs to be installed. the last computer no longer works.
Did you open your speaker ICON and check to see that you don't have the audio muted? I have seen a lot of customers complain that their NEW speakers don't work but they have their audio set to mute.
Mar 06, 2011 | Logitech Z-5300 Computer Speakers
I am missing the input cord from PC to speakers Where can I get 1 ?
It is most likely just the Stereo Audio Cable
http://www.buy.com/prod/cables-to-go-6ft-3-5mm-m-m-stereo-audio-cable-pc-99-cables-to-go/q/sellerid/14479157/loc/111/203022367.html
or a local Radio Shack or computer store may carry them
If this helps or solves the issue, please rate it and give a testimonial for my response.
Thank You,
Brandon
Dec 22, 2010 | Logitech Z-5300 Computer Speakers
Hi...
Im not sure if this will help u but check ur Remote's power botton.
Maybe its stuck?
It happened to me before... Was wondering y it turns itself on/off and found out later that the power botton on remote is stuck.
U should hear the clicking sound everytime u turn it on or off.
Otherwise... something else is wrong with the power switch on ur remote.
-Vash_Stepler
Sep 19, 2009 | Logitech Z-5300 Computer Speakers
I need drivers for my Z-5300 Logitech Speaker System
Sir,
check this site for download all logitech speaker driver. wareseeker.com/free-logitech-z-2300/
Thanks Good Luck
Sep 12, 2009 | Logitech Z-5300E (970102-1403) Computer...
Service manual logitech z 5300
Enclosed Image is from Z-5300 Manuel
Nov 28, 2008 | Logitech Z-5300 Computer Speakers
Z-5300 troubles
try dropping it from a tall building.
Seems to me you should go to Logitech support; they will be familiar with this problem, and should fix it in ** time, or else buy their newest, latest, most expensive replacement. If you are in warranty, and they can't fix it online, send it back for a replacement.
Mar 06, 2008 | Logitech Z-5300 Computer Speakers
Tony
Mar 03, 2008 | Logitech Z-5300 Computer Speakers
Is it possible to hook this system to my DVD
If you have RCA outputs on the Logitech Z-5300 then just plug the rca leads into your video or tv's audio out's
Apr 18, 2007 | Logitech Z-5300 Computer Speakers
Logitech Z-5300 Computer Speakers Logo
1,004 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
