Question about RCA HD52W56 52" Rear Projection HDTV
The picture on my screen is green no other images.
When I power up my TV, the screen is green with no other images and there is a crackling sound coming from it. Any idea what this could be? Also where could I locate the lamps inside?
    Genius:
  • 1,605 Answers
You TV is fried.
something is burnning inside of the set. most likely the high voltage supply.
Posted on Oct 20, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Image but no sound
I like your second option or perhaps exploding one with a shotgun blast
Oct 09, 2017 | Televison & Video
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Sony KP-51WS520
It is likely one of two things. Either one or more of the video drive IC's had failed, OR one or more of the CRT's (picture tubes) has filed. From personal experience with this model, I hate to say this but I see more picture tubes failing than drive IC's. In fact, if a picture shorts internally, it can also take out or blow up a drive IC. Unfortunately, with the costs involved, you're probably at the point where you have to decide whether to drop a bundle on this TV or invest in a new one. I would lean towards a new TV, because of the improvements in technology that have occurred and the possibility for fure failures with your current set.
Nov 08, 2008 | Sony KP-51WS520 51" Rear Projection...
The screen is showing red and green pixels onley and some picture on the back ground.
Turned TV on, crackling sound at back, streaks of red (like lightening) across screen, color out of whack. Any ideas of problem?
Sep 11, 2008 | Televison & Video
RCA HD52W56 52" Rear Projection HDTV Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
