Question about Fahrenheat Electric Convector Baseboard Heater, 3'
Farenheat baseboard heater F2544
How do I wire this thing up? I have a black wire, white wire and ground from electrical box. The wiring instructions are very vague, and not really of much help. There are 2 black, and two red on the thermostat that goes to the heater. There is one black from the thermostat on the heater, and one black from the heating element. Thank you for any help you can offer. Randy.
I just had the same problem last night. Wire the two red wires from the thermostat to the power source from the service panel. The remaining two black wires from the thermostat connect to the heater.
Posted on Oct 23, 2008
  • LAGB Oct 23, 2008
    meant to say that the white wire AND the black wire from the service panel are both hot and connect to the red wires from the thermostat. On my heater there was one black and one red from the heater - those connect to the black wires on the thermostat.
  • LAGB Oct 23, 2008
    found this website from the manufacturer. It explains it pretty clearly.
    http://www.marleymep.com/Develop/prod_pd...
    Problem Solver:
  • 10 Answers
You should have a licensed electrician connect this for you.
You did not specify the voltage. Baseboard heat comes in different voltages. If you connect a 240v unit to 110v it will work but only put out half of it's heat.
If you connect a 110v unit to 240v you will start an instant fire.
There should not be a thermostat on the unit and another on the wall. You can buy units for each application. You are probably looking at the thermistor which is a safety device which opens the circuit when there is too much heat. It must remain wired in series with the heat coil.
Also note that it is a violation of the National Electric code to install electric baseboard heat underneath an existing outlet. It is also common sense to not install it under drapes or near anything else combustible.
Posted on Feb 09, 2009
Thanks for the help, but I finally went online to their (farenheit) site that day, and there is a link there to a wiring diagram. I appreciate all the help, and THANKS!
Randy.
Posted on Oct 30, 2008
I have a black wire, a white wire, and a ground for supply. I have one red wire and one black wire on thermostat. I have two black wires on the heater that are wire-nutted together. How do I connect...
If this heater is 220 volt and the stat is 120 volt. Here you go. One black wire from the heater should go to the black wire on the thermostat. The red wire from the stat to your black wire in the electric rough in box. The other black wire on the heater will go to the white wire in electric rough in box. The ground to the appropriate ground screw on the heater and the stat. If you are not a licensed electrician in your state, you should hire one especially if you do not understand electric characteristics and the way energy moves or if you can not read electrical schematics. You can get seriously injured or killed wiring up electrical devices. Do not wire this heater up if your not sure of voltages, phase, and amperages.
Nov 19, 2010 | Fahrenheat Built-In Baseboard Thermostat...
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
I installed a 1000 watt four foot long Farenheat F2544 baseboard heater in my outdoor workshop. But it's too small for the space. I calculated that I probably need 2000 watts to heat my space. But I do not...
I could find no electrical code or mechanical code that says you can do that, so I wouldn't do that.
But have you thought of or do you have the overhead space to install a hanging unit heater? They don't require much space(just make sure you install it per manufacturers specifications) and they come in much higher BTU ratings.
Nov 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
How do I hook the wires up for a electric baseboard heater
this heater can usually be wired from either side. meaning your wiring can be brought through the wall inside of one side or the other.
the wiring you bring in to this unit needs to be 12g or larger.
it needs to be on a dedicated circuit. that means you cant splice into any other line. it needs to be for your baseboard heaters alone. that is code and wouldnt want to sleep in a house with baseboard heat that didnt have a dedicated circuit.
baseboard heat is most economical to run with 240v units. 120 is going to cost more to run.
you will need a thermostat either built into the unit or a thermostat unit mounted in the wall to run it.
dont mount the thermastat over the heater. I shouldnt have to explain why.
a 240 volt circuit run from your panel on a 20 amp breaker consists of 3 wires, a ground and a black and white.
in a 240v configuration both the black and white are hot and you must wrap some black tape around the white wire where it shows in your breaker panel and at the handy box in which you have installed the thermostat and then where it enters the heater. this re-designates the wire as a hot instaed of nuetral this gives you to black hots.
you hook the white and black wire to the line in side of the thermostat which should be the two red wires.then the two black load out wires of the thermastat run to your heater. hook your ground (green or bare) to the box if its metal and pig tail it to the ground screw on the thermastat, then out of that pigtail to the heater along with the two hot wires.
you will find a bare ground solid copper wire fixed to the inside connect your ground.
you will find two other wires they are both hots you will connect one of your hots to one of them and the other to the remaining.
what it looks like is an element sitting in the housing the housing is the baseboard and you have a hot wire running through a wire way to the other side and connecting to it and one hot stays on the side you brought the wires to.
in other words since you can wire it from either side you have to have a way to get the energy to one side or the other and they supply a way.
as long as this is labled as a 240 unit both wires are hot. take the covers off both ends you will notice the wire traveling from one side to the other. your goal is to have one hot connected at one end of the fillament and the other hot you brought in to the other end. the best way to hook up multiple heatrs is to have branch lines from the thermastat toeach heater, not to daisychain them one to the other becuase you will have voltage drop as a heater is using it before passing the voltage down the line leading to poorly functioning heaters
Mar 29, 2009 | Marley Electric Hydronic Baseboard Heater,...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
How do I wire up a F2544 baseboard heater with 220 wire?
in a 220 setup you don't use the white wire. just your other ones. just wire nut it off
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard heater connect
I have a fahrenheat F2548 baseboard heater, there were not any wiriing diagrams or installation instructions in the box where can I find the wiring diagram,
Aug 04, 2008 | Fahrenheat Electric Convector Baseboard...
Wiring a Fahrenheat model F2544 (1000 Watt 240Volt) Unit
There should be a wiring compartment at one of the ends of the heater 1/4 inch bolt holding the compartment shut. the link below will show you generally what it looks like rate me FIXYA! if this works.Good Luck.Oh yeah If I misinterpreted your question leave me a comment.
http://www.marleymeh.com/develop/prod_pdf/2500wiring.pdf
Nov 18, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
1,095 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
