Question about HP Compaq Presario v3000z Notebook
HP Compaq Presario A900
I am try to install xp and I am having the same problem. When I start to install XP it says I have no hard drive.
my e-mail id is dj_handicrafts@hotmail.com
CHANGE DRIVE MODE IN THE BIOS FROM SATA TO ATA
Posted on Dec 27, 2008
    Problem Solver:
  • 10 Answers
PLEASE GO TO A VENDOR,OR PLEASE TELL YOUR SYSTEMS RAM,HD SPACE,GRAPHIC CRD MEMORY AND THE OLD VERSION
Posted on Oct 20, 2008
Unistalling Microsoft VISTA HOME Edition
Are booting the laptop from the XP CD? If so it should just give you an option to delete partitions then format and install starts. If you try installing XP after Vista has loaded it wont let you as XP is older. Cheers from Scott
Mar 19, 2010 | Compaq Presario Notebook
I have a Compaq Presario V3309TU Notebook PC. I reformatted the hard drive, now I could not install windows XP cd. The hard drive could not be detected. Can someone help me get the SATA Driver for Compaq...
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 14, 2010 | HP Compaq Presario V3000T Notebook
Cant downgrade vista to Xp on HP Pavilion p6144f
This is a little confusing. What exactly are you trying to do?
Are you trying to wipe Vista off and install XP? If so, you must first reformat the hard drive and then install XP
Sep 23, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
XP drivers for Compaq Presario A900
Link
Run install reboot the run and install this link
This will create a swsetup folder in c drive ("C:\swsetup\sp34200")
Installing this driver may result in an error. But continue with the
following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click
Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp34200 folder and select the .inf (wis30b2a)
file and click open and Continue with the onscreen instructions.
May 28, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
HP Compaq Presario v3000z Notebook Logo
136 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
