Question about Honeywell Heating & Cooling
Fan on but no heat
We just moved into a 50s home with a honeywell chromatherm II (I think) thermostat, which has been working fine. Yesterday I noticed that it seemed cold in the house and the furnace wasn't cycling on and off. The fan remained on. When I looked at the thermostat, which I had set on "Hold 70 degrees", it read 69 degrees instead. I tried to adjust the temperature manually, but it kept coming back to 69. Even after turning the thermostat off, the fan kept going, so we flipped the breaker. My husband tried re-programming the thermostat, but it's stuck at 32 degrees, and the heat still isn't on, but the fan keeps running. Any ideas? Is this a furnace problem or a thermostat problem. My husband is wondering if the problem would be solved if we just bought a new, old-style round thermostat without all the programming.
  • 1,420 Answers
I never liked the user un-friendliness of the Chromatherm, I would suggest finding a thermostat that you can understand and operate. Yes the Chromatherm is a good one, but so damned hard to figure out. Stay away from thermostats that still use mercury. Good Luck!
Posted on Oct 21, 2008
I have a standard digital Honeywell thermostat. It it running the furnace in opposite modes.
not likely to be a bad thermostat, what model is the thermostat and heater?
Oct 12, 2017 | Honeywell Heating & Cooling
Heating& CA
would think that the thermostat has failed .
Jul 07, 2016 | Honeywell Air Purifiers
My Honeywell dt200 is displaying a flame when I turn it on but isn't actually heating.
The problem could be with the heating unit or furnace and not the thermostat.
Aug 10, 2015 | Honeywell Programmable Thermostat Heater
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
Airconditioning will not come on
And if what jumptrout51 said does not work, remove the thermostat to expose the wiring and place a jumper between (R) and (Y).
May 24, 2009 | Honeywell Heating & Cooling
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
Honeywell thermostat problem
Model number should be on the label inside the tstat
Nov 13, 2008 | Lasko Ceramic Heater w/Adjustable...
Heating & Cooling Logo
318 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
