Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn Air model SVD48600 clock
The clock in the control panel does not work. However, all other functions, such as fan, bake, broil, etc. work OK, although there are no lights or temp readings showing.
Does the whole clock assembly need to be replaced?
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Posted on Feb 28, 2009
  • 107 Answers
SOURCE: JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Posted on Mar 14, 2009
SOURCE: jenn-air svd48600w
If your display has gone dimmer and dimmer or just gone out it is probably the display board. There are a few capacitors on the back of the board. There is one that is 68 Microfarad 35 Volts. It is common for this one to go bad. I replace it with a 68 Microfarad 50 Volt rated one and that usually solves the problem.
Posted on May 18, 2009
  • 10865 Answers
SOURCE: My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
Posted on May 31, 2009
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
The baking does not work
sounds like the touch pad or main control board could be bad...call for help on checking components....
May 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jenn-Air range SVE47600W control panel is partially non-functional. Bake temperature control, off, oven light work. Clock does not display, oven clean and broil do not function. It may need a new panel...
We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
Oct 15, 2009 | Ovens
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Aug 11, 2009 | Kitchen Ranges
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
95 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
