Question about Dymo DateMark Date/Time Stamper
It prints different from display screen
It prints something different than display screen.
  • 1 more comment
  • ups5 Nov 11, 2008
    on the display screen it shows the correct date, time, and everything. but when i print on my time sheet for work it comes out as " 196087 14568714684" random numbers.
  • Anonymous Feb 13, 2009
    The time and date will not print. It prints rcvd 60009 instead of the time and date.
  • ups5 May 11, 2010
    I am trying to print out the date and time and "in" or "out" like it shows on the display screen, but a series of numbers and letters that don't make any sense gets printed out instead. please help.
    Genius:
  • 2,985 Answers
What prints different?
What Display Screen?
What are talking about?
Buckup
full details gets the answer
I know about computers
I am not into mind reading
Assuming you have one that is?
Posted on Oct 21, 2008
Need to make the print size smaller on my deskjet 3700 printer please .
Unless the printer has it's own menu to allow you to do this the print size should be adjusted at the source of the text you are printing, in the word processor for instance.
Generally a printer will print only the files it is sent in the form they have been sent. If you need the printer to print something different you mostly need to send it something different.
Set up the document you want printed on-screen and use the tools available in the programme you are using to adjust the document until you are satisfied and then send it to the printer.
Feb 14, 2017 | The Office Equipment & Supplies
My printer is skipping lines. do I need to clean something?
1. Make sure that the machine is turned on, open the Paper Output Tray, and extend the Output Tray Extension.
2. Load a sheet of A4 or Letter-sized plain paper in the Cassette.
4. Start Print Head Deep Cleaning.
(1) Press the Menu button.
(2) Press the or button to select Settings, then press the OK button.
The Settings screen is displayed.
(3) Press the or button to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
(4) Press the or button to select Deep cleaning and then press the OK button.
The confirmation screen is displayed.
(5) Press the or button to select Yes and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep Cleaning finishes. This takes about 1 minute 30 seconds.
5. Check the condition of the Print Head.
(1) Print the nozzle check pattern to check the print head condition.
(2) If the print head nozzles are still not clean, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
Jul 01, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Print is small in comparison to the screen.
Sometimes the Screen Letters or graphics do not match the Print out. You should tweak the Control Panel Display Setting, and change the Color configuration.
Or you can also go To Control Panel and Printer Setting, and change the Color Setting of the Printer. Usually if it is RGB, the print out would be different from Monitor or Screen.
Sep 07, 2010 | HP LaserJet 1018 Printer
HP 6110 is printing different color than on the screen
computer monitors are capable of thousands if not millions of shades and hues of colors that even the most expensive professional grade printers simply can not print. greens in particular. if your creating something you know you'll want to print (say like a business card), you need to create it in "printable" colors. there are programs (like paintshop and photoshop) that can display on your monitor what will actually print. the results will shock you. all this post of course ASSUMES your printer is in proper working order, otherwise your problem will be magnified...
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
An 'etch-a-sketch' - type image that at quick glance, looks like an elephant, appears in the upper right section of the screen. It isn't captured with print screen. Swapped out monitors to different CPUs....
I did see a similar issue with a Gateway display, the source of the image was the screen is damaged by the cover inside the screen. Basically, the inside frame was scratching the back of the screen making the image to appear until it damages the screen enough to turn off pixels.
Another possible cause are: "burned pixels", some kind of damage (liquids inside the display), the display was hit, or something like that.
The only solution is to replace the display or use it until is breaks (but it will be quite annoying).
Mar 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
How can i make my mp460 printer wireless
If you are using Windows follow these steps:-
Printing with Computers (Windows) via Bluetooth – Windows
  • Note: A different screen may be displayed depending on the application you use. This section gives a description using the screens displayed under Windows XP SP2.
  • Bluetooth communication distance: Approx. 10 meters in normal environment.
1. Turn the printer on and load paper.
2. Create a document or open the file you want to print.
3. Open the Setup tab of the printer driver.
(1) Select 'Print' from the File menu of the application
The Print screen appears.
(2) Select the printer to which you attached the Bluetooth unit such as Canon XXXXXX (Copy X) .
  • Note: "X" is a device name or a digit. The number of Xs varies depending on the device name.
(3). Click 'Preferences' (or Properties).
4. Make settings necessary for printing.
(1) Select a media type from Media Type.
(2) Click 'OK'.
  • Note: To check the paper size, click the Page Setup tab. If it is different from the size specified with the application, select the same size as that specified with the application.
5. Start printing.
(1) Click 'Print' (or OK).
Feb 16, 2010 | Canon PIXMA MP460 All-In-One InkJet...
My Nikon D70 lcd screen doesn't display correctly the colors on the screen show in bright glowing colors, but the pictures print out great and display well on my computer screen. Is there a setting that...
You are looking at two different monitors with different settings. In most cases you will need to do some editing yourself on your computer because of the difference. Or the brightness can be done in a lab.
Mar 22, 2009 | Nikon D70s Digital Camera
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
199 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
