Question about Lexmark Office Equipment & Supplies
I replaced ink and paper..paper keeps jamming when printing and copying. after the replaced inl and paper, i was able to print with no problem however without warning iunable to print or copy without paper jamming..
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 20, 2008
The black inl isn't printing out only the colour
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 01, 2012 | Canon Sealed Pixma Mx870 All-in-one Inkjet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Unable to print or copy, see troubleshooting 51
The error means you have a paper jam or one of the sensors is incorrectly reading a paper jam. Unplug the unit and check all areas for a jam. Remove the back Jam Clear Cover and check inside there. Remove the Paper Tray and check that area and check if the PE actuator is in place behind the paper tray. Lift the scanner flatbed unit and check inside the print carriage area. Look for scraps of paper at the sides of the platen. These scraps that may be soaked with ink and difficult to see. You may need to move the print head to see both sides.
If the PE actuator is missing, contact Brother for a replacement. Put in the replacement if needed.
Close the scanner unit, replace the clear jam cover (put it on correctly) and replace the paper tray. Plug in and turn on the printer and see if the message clears. If it doesn't clear, access the Ink or Ink Management menu (either directly by a single key or through the menus). Do a test print for Print Quality (Color). If the quality is good, press 1, the up arrow or + key to select Yes. Then press the Stop/Exit button. If the print quality is poor, clean the print head.
If the jam message occurs again, check for more scraps of paper inside the unit as above. Make sure your paper meets the specifications for the printer and isn't getting excessively humid. (Paper will pick up moisture from the atmosphere so keep only the needed amount in open reams or the paper tray.) Fan the paper in the tray and then return it to the paper tray. Make sure the paper is flat in the tray and that the guides are just touching the edge of the paper.
If it still doesn't clear, the unit needs service.
I hope this helps.
Sep 14, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Chews up paper while printing then jams paper.
Top loader or bottom loader? Ink-jet, dot-matrix or Laser? All have different reasons. Most common are ink-jets. Most common are top loaders. Most common cause is cheap paper. Buy ink-jet paper. Most people buy cheap copy paper (20#). Buy a good 25# or heavier paper to keep that from happening (especially w/ top loaders). People always worry about that extra dollar or two for paper, but it take an average of 10ml of ink to print 300 pages. That's 1 cartridge ($10 to $20 dollars) for less than 1 package of paper ($3 to $5).
how to clear paper jam: http://www.ehow.com/how_113761_clear-printer-paper.html
Apr 05, 2009 | Office Equipment & Supplies
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
If paper has jammed in the printer, clear the jam, replace the paper in the printer
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
