Question about Canon EOS 550D Rebel T2i Digital Camera
Error 05 on canon eos 550 d
I ve canon EOS 550d camera suddenly a error 05 has occurred in which its giving " The built-in flash could not be raised. Turn the camera off and on again." even when the flash is open. Because of it the flash is not working
    New Friend:
Tryed everyones sugestions for erros 05.3 clicks but non worked until i took the flash cover of by takeing 2 screws out very easy and then loosenedthe screw with the spring until flash moved freely
Posted on Apr 09, 2013
    New Friend:
  • 9 Answers
I'm using canon kiss x4.. having same problem.. and use to do a slight "tick tick" on flash.. and that pops up.. and once its popped up. i don't close it down until i finish my photography session.. because it saves a lot of time.. and where there i don't need flash i just disable flash from with in menu... it's ok for me
Posted on Dec 31, 2012
I pulled up manually as it tried to open and wiped down the flash and sensors now works fine.
Posted on Sep 19, 2012
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
robshow
  • 367 Answers
SOURCE: The flash on my Canon EOS 400D won't work
Can you pull it up manually, Be careful when doing this but try opening it manually, it is possible that the catch for the flash is just stuck temporarily.
Posted on Jan 05, 2009
SOURCE: cANON eos 450D error 05
I have had the same problem with my 450D. I have been living without flash on my cam for a month. Until I realized that maybe something liquid and sticky by chance got where the flash is...so i just trid to hold uo the flash my insrting my nail into the small space between the flash and the camera and tried to press the flash button. IT WORKED!!!
Posted on Jul 19, 2010
  • 155 Answers
SOURCE: canon rebel eos ds6041
DS6041 is the model number for Canon EOS Digital Rebel or 300D. It is a 6.3 megapixels DSLR camera from Canon.
All software and manuals available from the Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=9430
Posted on Feb 18, 2009
SOURCE: Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Posted on Jan 10, 2009
  • 57 Answers
SOURCE: Error 05
Usually grit or something sticky causes the flash movement to seize. Window cleaning fluid on a cotton tip works best.Clean remaining residue with methylated spirits on another cotton tip. Water based cleaning should be avoided as it may corrode components.
Posted on Apr 04, 2009
My canon 550 d camera lens dose not zoom autormatically
a 550D is a detachable lens camera and will not auto-zoom (it has a rubber ring that you turn to accomplish this with most lenses). are you sure you have an EOS 550D, or did you mean auto-focus?
Apr 24, 2014 | Canon EOS 550D Rebel T2i Digital Camera
Tip
EOS Converter-Transcode Canon DSLR 550D Video to ProRes 422 in Full HD 1080p for...
Convert/Import Canon Rebel T2i/550D 1080/30fps H.264 MOV to ProRes 422 Codec for FCP 6/7 <br /><br />Canon EOS Digital Rebel T2i / 550D recorded videos are saved in H.264 for image and linear PCM for audio. You can choose different recording modes like full HD 1920&times;1080p at 30/25/24 fps, HD/SD 1280&times;720p/640&times;480 at 60/50 fps. Even though the videos are saved in .mov format, you may also face problem importing the video to Final Cut Pro. So you need a Mac Canon EOS Video Converter for converting and importing 550D1080p MOV for Final Cut Pro without rendering. Aunsoft Video Converter for Mac is the recommended <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac Canon EOS Converter</a></b> for you to edit Digital Rebel T2i / 550D videos. <br /><br />Below is the quick guide for those who have a hard time editing Canon EOS Digital Rebel T2i / 550D H.264 MOV files to ProRes 422 at 30fps in Final Cut Pro 6 or 7. <br /><br />Step 1. Download Canon 550D MOV files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/convertimport-canon-rebel-t2i550d-108030fps-mov-to-fcp-with-prores-codec/">Canon EOS Rebel T2i H.264 MOV to ProRes MOV converter</a></b> on Mac OS X. Click the "Add" button to import .mov files from the camera. <br /><br />Step 2. Choose MOV format with ProRes 422. <br />Click the "Format" option, and navigate to Final Cut Pro &gt; Apple ProRes 422 (*.mov) as output format. The Mac Digital SLR camera video converter will convert H.264 mov to prores 422 mov. <br /><br />You may notice that there are also other options like Apple ProRes 4444, Apple ProRes 422 (HQ), Apple ProRes 422 (LT), Apple ProRes 422 (Proxy), DVCPRO HD 1920*1080 30fps etc. <br /><br />Step 3. Choose 1080p size with 30fps. <br />Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution and 16:9 aspect ratio. Click the drop-down box for frame rate, and you can choose 30fps. <br /><br />Step 4. <b>Convert DSLR video to ProRes 422 HQ MOV for FCP.</b> <br />Click the convert button under the preview window, the <b>Mac Canon 550D DSLR video converter</b> will start <b><a href="http://prores-converter.com/2011/06/eos-converter-transcode-canon-dslr-550d-video-to-prores-422-in-full-hd-1080p-for-fcp-editing/">converting DSLR video to ProRes 422 in full HD 1080p for FCP editing</a></b>. <br /><br />After the conversion, you can import ProRes mov to Final Cut Pro without rendering.Hope you enjoy the optimal way to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon H.264 mov to ProRes 422 for FCP 7 and 6</a></b>, so that you can edit the H.264 files easily.
on Jun 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Error 80 on my canon 550d
Have a look here at the Canon Error codes
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
Apr 21, 2014 | Canon EOS 550D Rebel T2i Digital Camera
My canon eos 550d shows error 80
ERR 80: SHUTTER
DESCRIPTION: This error occurs in the following conditions.
When the CAMERA self-check system detects that the shutter has not been fully charged (ready to shoot).
When the CAMERA self-check system detects that the shutter operation sequence has not been completed correctly.
When the built-in flash cannot be recharged after the E-TTL preflash but before the main exposure.
REMEDIAL MEASURE: Try clearing the error by turning the main power switch OFF and then back ON.
Feb 05, 2013 | Canon EOS 550D Rebel T2i Digital Camera
I recently purchased a Canon EOS Rebel T3i SLR camera (July 2011) and already I am encountering a problem called "Err 05 the built-in flash could not be raised." Does anyone know how to resolve...
Hey Leo,
Unfortunately the problem you've mentioned is quiet common with your particular model.
Here's what Canon recommends, on its website.
-Turn the power switch to < ON > to turn on the power again.
And, if that doesn't work. Buddy, you'll have to drop by a service center. Hurry up, or you'll run out on the warranty period.
Toodles,
Rebel K
Sep 18, 2011 | Canon EOS 550D Rebel T2i Digital Camera
My new canon rebel T2i/EOS 550D Flash is not opening when i press shoot, it tries and tries and tries and show error 5.
A 5 error is the camera thinks the flash is not raising. Look near the hinge for a small button and see if it is up or down. This lets the camera know is the flash is up or down and if the button is stuck down you will hear the motor fire a few times and it will then error.
Unfortunately, this is one of the problems that starts to appear on cameras with pop-up flashes. You can hit the button and pull it up at the same time. Only other option is to send it to Canon to get it repaired.
or, Get an Speedlite like the 430EXII or 580EXII. The flash unit may make your camera bigger, but the results will be much better once you learn flash techniques.
Mar 12, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Error 05 the built-in flash could not be raised
I had this issue.
  • Gently pried the flash up with a pocket knife while I pressed the flash button.
  • Cleaned all around the flash and moving parts with a q-tip.
  • Moved the release and tiny button a few times to make sure nothing was stuck.
  • Turn off then on and test.
  • Seems to be working fine. May have just been some goo in the release or causing the flash to stick to the body.
Feb 12, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Whats the difference between Canon EOAS 550D /Rebel / non rebel? Which is better camera?
Identical Canon models are sometimes marketed under different names in different parts of the world. Rebel cameras are known in America and EOS cameras are known in Europe. For example the EOS 550D is called Rebel T2i in America. They are in fact the same camera they just don't have the same name.
Nov 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
Err 05
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 550D Rebel T2i Digital Camera Logo
1,402 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
