Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
Converting From 12/24 to Starght 24 Volt
I just purchased a new Minnkota trolling motor that is straight 24 volt. My previous trolling motor was a 12/24 volt which had the 12/24 volt switch on it. Per the two batteries, there are four wires (red, black, orange, and white). I'm not sure if I'm getting full power, and when I plug in my on-board charger after fishing, only one battery show as red--the other one is still green, like it hadn't been used. Are my batteries connected correctly for a 24 volt trolling motor. Someone told me that I needed to connect two jumpers to the batteries (negative to positive for both batteries). I'm not sure and haven't tried that. Does anyone have any ideas or remedies to my problem.
Robert
  • 3 more comments
  • Anonymous Mar 22, 2014
    Just bought
    the boat
  • Anonymous Mar 26, 2014
    If red goes to positive and black to negative, why/what purpose does the n/c line serve.
    Unit is a Lowrance sonar unit, not a trolling motor. What is the purpose of the third wire on the power line to the unit.
  • Anonymous Mar 28, 2014
    is it possible to connect trolling motor batteries 2 12v parallel with the MK 330 3 bank charger.?
    To get a good solution fast, you should:
    Describe the problem
    Specify the product
    Add additional details
    how to match up a 12/24 volt foot pedal on trolling motor to a 24 volt motor head?
    Genius:
  • 1,605 Answers
If it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Converting From 12/24 to Starght 24 Volt - fee9d8c.gif
Posted on Oct 20, 2008
    Problem Solver:
  • 8 Answers
The batteries must be connected in SERIES. The method described is proper, but the name of the method is wrong.
On the female plug for the motor on the boat, if you have the wiring for TWO separate batteries coming to the plug, the male plug must have a jumper in it. To find out, disconnect the batteries one at a time and voltage check to see if there are two separate battery systems there. There probably are. If so, the series circuit is provided for in the male plug by the jumper and not in the back of the boat where the batteries must be wired independent of each other.
Posted on Nov 28, 2008
5 years ago I bought a Prowler 12 Volt Trolling Motor, but due to poor health it wasn't installed. I'm in search of an operators manual so I can install/operate this Trolling Motor.
Here you are. You can download your manual from the Internet.
I use GOOGLE and typed this in ***** (Prowler 12 Volt Trolling Motor, manual.) **** Simple and fast. You can copy and paste this to the browser Prowler 12 Volt Trolling Motor, manual
Oct 20, 2017 | Boating
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
    You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
    Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
    Minnkota Traxxis Model 1368716 will run in reverse only and not forward
    it could be the coil pack in the nose cone of the trolling motor which is not serviceable but can be replaced at a reasonable cost. it could also be the switch in the handle but it seems less likely. there is a test protocol to follow if you know how to use a volt/ohm meter. call the 800 number on your motor and have the tech send or email you the testing proceedure. they are very helpful and can give you the prices on the parts you need. good luck.
    Jun 20, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
    3,058 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
