Question about Krups FME2 Coffee Maker
Krups FME2 Error Message
Our CM is less than 1 year old. Yesterday the heating plate was luke warm and today no brew happening at all. Error message "empty water resevoir" appears and the heating element seems to be toast. Thought we were purchasing a top-of-the-line product. Any suggestions?
  • 1,605 Answers
If you still have the receipt, you can get it repair or replace under the warranty, unless the warranty is for 90 days. in that case you are toast.
time for a new one.
replacing the parts is half the price of a new one.
Posted on Oct 20, 2008
Krups FME2 coffee maker won't brew. Flashes an error ---
Most coffee brewers has what is call "resistance" . This resistance get hot to boil the water then brew the coffee and in most cases the resistance get burn and dont brew.
Apr 06, 2015 | Krups Coffee Makers & Espresso Machines
No coffee!!
You might need to set the clock try that
May 01, 2013 | Coffee Makers & Espresso Machines
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at
Oct 30, 2009 | Krups KM7000
Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
Oct 07, 2009 | Krups Coffee Makers & Espresso Machines
Flashing 8888 will not make coffee
I had a similar problem. It stopped working mid-brew, then flashed 8888 incessantly and I couldn't get anything to respond. I unplugged, turned it upside down overnight to drain. Next day it worked fine and has been OK since.
Aug 08, 2009 | Krups FME2 Coffee Maker
Error message states no water, but there is...
Unplug the device and plug back in after 1 min. If it still fails, then you have a dirty water level sensor or the control circuit board is fried. Empty the water out and fill it with vinegar as full as you can without overflowing. Let it soak overnight and turn the machine on (without coffee in it). Turn off after 30 secs.Turn on again and allow it to finish the cycle.  Discard the vinegar. Run three more brewing cycles with water only and it will be OK to use. If this does not cure it, then the only cost effective way is to replace it.
Apr 26, 2009 | Krups FME2 Coffee Maker
Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Apr 07, 2009 | KitchenAid KCM511 Coffee Maker
Krups XP4030 is stuck in the steaming mode
Here is a link for the manual. It says on Krups web sight they have a 1 year warranty,
Nov 02, 2007 | Krups XP4030 Espresso Machine
Krups FME2 Coffee Maker Logo
335 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
