Sony KV-27S20 27" TV
Problem for Sony KV-27S20 27" TV
How to find pins for the EHT and FBT.
By franko on Jun 30, 2006
Thanks for the responses. I have done some electrical soldering but have never had my 27' Sony apart. Where would I find the pins for the EHT and FBT? They are probably on the board but where. I don't have a schematic unless there is one inside the TV. Any extra info would be appreciated. I don't want to bring it in unless I have to. Do I need to purchase a service manual? The actual model is a KV-27V20.
Best Solution
posted on Jun 30, 2006
Very Helpful)
techman
Rank: Guru  Sony Expert
Rating: 86%, 7673 votes
Franko, If your sure about troubleshooting HI VOLTAGE then disconnect the horizontal output transistor first. Is it shorted? if it is get the fly and the transistor. But I wouldnt start it up with out a variac transformer. For the parts, go to http://www.partstore.com amd see what the parts cost or get the tele # and call them. BE CAREFULL. Good Luck
Was this helpful?
Yes
No
Solution #2
Helpful)
Pravin
Rank: Wiz  Sony Expert
Rating: 83%, 647 votes
Franko, The FBT and the EHT are one and the same.
It is a big block, generally found at the rt side of the PCB board. It has two leads - One Red going to the Picture Tube, and another Black going to the Small PCB on the Neck of the Picture Tube.
will also have 2 controls - Screen and Focus.
Just slide the PCB out ( Mind you, remember to unplug your set, and wait for an hour or so to enable the High Voltages to discharge, before you you try any soldering.) Also, remember to wear Rubber soled footwear!
After sliding the PCB out, tilt it partially, and solder the pins which are part of the FBT. Also try resoldering the Hor. Output Transistor Terminals (Generally mentioned as Q801 in most SONY TVs)
Slide the PCB back in, and close trhe set. Try switching it ON again.
Was this helpful?
Yes
No
Popular Solutions for Sony KV-27S20 27" TV
Questions and Unsolved Problems for Sony KV-27S20 27" TV
Do you recommend Sony KV-27S20 27" TV?
Answer
Answer
Sony WEGA tube 34" 4.5 years old. The picture hue is all green/yellow/blue - no red. When I... (More)
Answer
i have a hitachi 36 tube type tv that the picture is slowing geeting darker. even if i turn the... (More)
Answer
have a 42' tv and i can hear the pictrue but cant see it
Answer
I don't have remote control. How do I use capture (subtitle) function for deaf ?
Answer
I have a 32" (?) Sony TV that is 12 years old. It is a floor model that is incased in wood with... (More)
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
