Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony Rear projection TV problem
Hi There, I have a Sony KP-46WT510.....the sound comes on for about 6 seconds (no picture) and then it shuts off.  The red LED on front flashes 8 times.  What do you think???
Thanks, Lauren C.
  • astor3000 Oct 24, 2008
    I have the exact same problem blinks red 8 times but no screen can anyone help us please i don't want to spend the money on finding out if it's fixable or not. If anyone has had this problem fixed please tell me how. thanks
Hi, i had the same problem today. i took a risk and opened the front bottom panel(regular star faced screws located at the side) where the speakers and buttons are located. then i unscrewed the panel located right below it. i then unplugged the wires that were connected to the bulbs(sorry i dont know the technical term for it but there should to be blue,red,and green bulbs). when i reconnected i turned it on it was fine. its been about six hours now and it's working perfect. hope this helps.
Posted on Nov 01, 2008
  • sunnyNYC Nov 01, 2008
    sorry i forgot to mention before, i took off the power supply before i performed all the above mentioned steps. also, when i disconnected the bulbs, i left the wires off for about an hour.
I have a new smart blue ray player and am trying to set it up using a hdmi cable to my sony KP-46WT510 tv and I have video but no sound?
Two things come to mind. !. are your cables plugged in right? Yellow->yellow, red->red, white->white? 2. Is the sound on the TV itself turned up?
Nov 28, 2013 | Sony KP-46WT510 46" Rear Projection HDTV
What's your problem?Hi, I have a Sony projection TV KP-46WT510 theres no picture or sound, but it still turns on and I can see the the on screen menu. When I turn it on the led blinks four times
You can Google and find the service manual which will explain what the 4 blinks means.
If you have the Sony remote with the set off:
Display, 5, Volume down, Power
If the set has it you will see a box appear on screen with a list of items--all should have a zero to the right of each---one with a number indicates the number of times that error has been detected.
Let me know if you have questions or cannot find what the four means and I will research it.
Mar 28, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
No picture or sound
3 times error shows that lamp is not installed properly or lamp cover is off / not fixed.
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jan 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
65 sony rear projection 2003
Your flyback transformer needs replaced.
Apr 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
What is wrong?
Sweep and chroma circuit problems. Have checked by pro/tech
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-46wt500 problem with picture
i'm having a problem keeping the timer from going off and shutting the whole tv off.
Mar 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
675 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
