Question about Jabra BT250 Consumer Headset
Jabra Bluetooth not charging and startup
Hi I am Ellin Scott, Could you help me.. My Jabra Bluetooth device not working.. email me:techin(dot)scott (attherate)  gmail dot com
model no:  BT 250, no signal in Charger also not with Mobile
  • Puneet Jain
    Puneet Jain Oct 21, 2008
    Do you provide service??
  • 53 Answers
You can visit an expert technician for hands on service.
Posted on Oct 20, 2008
PAIR WITH MKI9200 PASSCODE
Usually, the factory preset 'pairing code' for a Bluetooth device is:
0000
Give it a try...
Scott
Jan 13, 2012 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Hi I have an iPhone 4 and jabra bt3030 worked perfect on my iPhone but in my iPhone I tap forget this device and the device was gone! now I can't find it again! what should I do?
    • 1. Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. It is the button that has an image of a telephone on it.
    • 2. Click on the "Settings" icon from the main screen of your iPhone.
    • 3. Click on "General" in your iPhone's "Settings" menu.
    • 4. Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
    • 5. Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
    • 6. Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
    • 7. Click on OK on your iPhone
Sep 13, 2011 | Jabra BT3030 Wireless Headset
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Feb 07, 2010 | Jabra Bluetooth Headset with Adjustable...
I have a Jabra set, but my Motorola Krazer can not find it
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Jabra BT350 Bluetooth Headset Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Not able to connect Jabra BT 125 to Laptop
Correction to the above note...
You can connect your Jabra 125 to your computer's audio output and listen to music via the ear piece. You need to make the adjustments in the control pannel. Set the audio/sound output to the blue tooth. You also need to sync the earpiece to the pc via a dongle or bluetooth adapter on the pc. Works great...
Jimmy
www.CLSONLINE.org
Feb 16, 2008 | Jabra BT125 Headset
Jabra BT 350
u gotta make ur jabra go to FIND ME Mode, u do this by turning it off, Turn it back on by pressing power for 6 to 8 seconds until the light is in flashing mode, and make Ur razor look for devices and pair it with the 0000 code. hope this works for you
Feb 11, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Jan 03, 2008 | Radio Communications
Jabra BT250 Consumer Headset Logo
269 people viewed this question
Top Jabra Radio Communications Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
vimal
vimal
Ed Nelson
Ed Nelson
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
