Question about Viking DDBB363 Bottom Freezer Refrigerator
Fridge light not shutting down, alarm on, temperature heating up
The fridge alarm sounded this morning. I shut the alarm off. I made sure the door was shut. The temperature inside the fridge felt warmer than usual. The motor wasn't shutting off -- kept humming. Then, I noticed a burning smell and felt intense heat from the light bulbs. So, my husband shut the power off and removed the light bulbs. We turned the power back on.
After a few hours, the motor has stopped humming. And I haven't checked the temperature yet. The only thing that has changed from last night to this morning was that I put a bunch of groceries in the bottom fridge shelf like plastic bags of vegetables that I couldn't fit into the crisper. The fridge seals seem tight all around.
My question is: Is there a switch within the hinge that triggers the light to shut off? Why is the light not shutting off with the fridge door shut? (we checked by putting a timed camera in the fridge when we shut the door and the light stayed on ... thus creating the burning smell and upsetting the temperature)
Thanks,
  • anniekrons Jan 10, 2009
    Fridge light not going off, temperature warm, but fan continues to operate. Freezer ok.
  • mgouin Jan 18, 2009
    It's the same problem.
    Please notify me with a solution.
    mariegouin@alumni.neu.edu
  • 42 Answers
You do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Posted on Dec 21, 2008
  • 4 Answers
SOURCE: Bottom Door Shelves and Vegetable Crispers Freezing up
I just had a similar problem, and the bottoms of both sides were cold but the top shelves were warm. I found that the condenser fan, the fan right above the cooling coils was not working. This fan circulates the cold air and if it's not working it can't move the cold air to the top or over to the refrigerator side. Open the freezer door and press the switch that tells the computer the door is closed (so the light goes out), if the fan doesn't come on shortly, or only sputters that could be the problem. You will need to take out the back cover over the coils, the ice maker tray and auger motor if you have one and some other parts. Play around with the plug where it goes into the side wall, if you can get the fan to come on and off, it's most likely a bad fan motor....about $55 to replace. As you take it apart, be sure to take some digital pics of the process so you can remember how it goes back together!
Posted on Feb 13, 2009
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
woodchuck789
  • 4070 Answers
SOURCE: vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Dec 17, 2009
  • 1531 Answers
SOURCE: broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Posted on Feb 09, 2010
Sea Breeze
  • 4655 Answers
SOURCE: Maytag fridge MSD2356AE freezes vegetables in the
Click Here=> Service Manual MSD2356AE I believe you are having problems with the auto damper 61005993 or 1005661 Auto damper.
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Feb 26, 2010
Testimonial: "Thank you. Will test the unit as described in the service manual to determine if it is the culprit."
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
My Amano top/bottom fridge freezer has no temperature in the fridge- my wife taped the light shut which left the control panel showing nothing but now the fridge works- my tech nician said I need to change...
A light switch failure can leave the light on even with the door closed, raising the temp. to over 40 degrees. Firstly, make sure doors are not sagging creating a switch activation with the door closed. If that checks good, replace the door switch.
Oct 07, 2017 | Amana ABB1927DE Bottom Freezer...
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
Our tenant says she heard the fridge beeping late last night. This morning, the fridge is completely shut down. The electrical outlet that it's plugged into has power, but the fridge isn't working. Is...
Do the lights light up in the fridge or freezer? If so then your power will be fine. If you look into the fridge do you have a board that sit up the top front with the temperature for the fridge a freezer on it? It will either be that board (most common) or the start relay which connects onto the compressor in the rear of the appliance, they can sometimes burn out and stop the compreeeor starting and the appliance will lose the temperature and the noise you hear is the alarm warning you that your food is at risk.
Nov 04, 2010 | Maytag MSD2756GES Side by Side...
I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
May 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Motor continuously runs.
What you describe sounds like the fridge is not making temperature for the thermostat to shut off. What number is the thermostat on? 0-6 usually a setting of 3 or 4 will do. Try turning the thermostat down to 1 to test it, does the compressor stop? Place a thermometer in the fridge for an hour with the thermostat on 4 and keep the door shut, if it doesn't get below 7'C (1)Check your door seal is clean and seals all the way round when you shut the door. (2)The cold element is frosted up and can't work properly-defrost the fridge. (3)If your sure the compressor is rotating then your fridge requires regassing, although this means potentially there is a leak and no guarantee can be placed on how long this will last.(mine was 5 years between gassing)
Aug 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge - Westinghouse siloueete frost free 415 problem
Temperature sensing thermostat could be going bad. Also check to make sure the refrigerator light is shutting off when you close the door. There should be a switch to control the light operation when the door is opened and closed. Operate the switch by pushing it in as if the door was closed and make sure the light goes off each time.
May 18, 2008 | Refrigerators
Ddbb362 viking designer
It sounds like the light switch may be keeping the light on when the door is closed. Faulty Switch. Regards Advisor
Aug 19, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Viking DDBB363 Bottom Freezer Refrigerator Logo
586 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
