Question about Kenwood DV-6050 Multi-disc DVD Player
WILL NOT LOAD DVD OR CD
UNIT WILL POWERUP AND THE DISPLAY WILL SAY LOADING HOWEVER IT NEVER START, YOU CANNOT OPEN THE TRAY, IT WILL NOT RESPONDE TO ANY OF THE BUTTONS. IT JUST DISPLAYS LOADING
  • 2,071 Answers
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
I close the tray. DVD player immediately re-opens the tray and leaves it open. If I repeat, it does too. I just did the firmware upgrade, still re-opens the tray. Samsung bd-c5900/xaa.
Check and replace the loading belt, then check for alignment of the tray and tray sensor. You may be able to replace the belt without taking the DVD player apart but you will need to take it apart if the tray needs to be removed and then realigned to the loading mechanism.
Usually, the tray needs to be removed, carefully, then turn the loading gears all the way back and then slide the tray back into position. All of this with the unit unplugged of course. Sometimes the belt. The belt tension and size need to be perfect for the unit to open/close and load the disc correctly.
Jul 18, 2011 | Televison & Video
Disc tray cannot be opened
Hi, The unit is in initialization/reset mode immediately after powerup. It does a self diagnostic sequence. When a fault is detected, it actually locks up till the fault is removed/repaired. A couple of things you can do: 1. Unplug the unit from the mains for a couple of hours; 2. Check your manual if there is a hard/full reset sequence/button and perform it; 3. Remove the topcover and inspect the loading tray. There is a possibility that a CD is stuck, lodged or skewed inside; 4. There is also a possibility that the loading mechanism is stuck, defective belt/gear; 5. if the unit is still under warranty, require service or replacement; or 6. if no longer under warranty, seek the services of a qualified professional. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | iLO DVDRH04 DVD Recorder
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
I have an RCA DVD/VHS combo with TVG. The DVD
This is a work-around rather than a solution. We put an audio CD in the tray and after closing the tray the unit begins to play the music. After waiting a few seconds we open the tray and quickly substitute a DVD and it loads OK. We had also tried cleaning the player to no avail. The CD approach is a pain but it does allow us to play DVDs. Jim
Jan 15, 2010 | RCA Televison & Video
Jvc dvd receiver xv-thu1 says locked when i press eject
Hello Dude !
There reasons why your DVD tray won't eject
1, a cd got stuck inside
2, Motor belts are loose
3, Loading motor faulty
4, Main loading gear damaged
5, Somebody must have pushed the loading cd tray forcing it to load and waiting for it to load the cd by its self so it has jumped its setting .
If so you have to remove the loading tray and put back correclty then it should load by its self .
Good luck
Nov 13, 2009 | Televison & Video
SA-HT650 Home theatre system Disc does not spin
i think the problem yet, is not the motor.it will start spinning once the tray or its loading sequence is close or it says close.better check the rubber belt for tightness.because if you can manually operate the loading, it only means the its not totally closed.there is a small switch just under it that needs to be closed.the rubber belt can be found under the cd tray.i suggest the you call a tech to open the unit up for further troubleshooting and advices.
May 07, 2009 | Panasonic Home Theater System System
Can't open loading tray on Yamaha RDX-E700
Is there a pinhole in the face of the DVD player near the drawer?
Apr 01, 2009 | Audio Players & Recorders
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Controll panel is not working.no display.dvd is loading ok
This seems to be a common issue with this model. Try replacing the jumper cable on the unit (which goes from the CD Tray Unit to the CD Head/Display Unit). If that does nothing, you will need to get it serviced professionally, as this would then be an internal issue.
- TWEAK A/V LAB
Oct 25, 2007 | Numark DVD01 Dual DVD Player
Kenwood DV-6050 Multi-disc DVD Player Logo
530 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
