Question about RCA F32450 32" TV
HELP TV WILL NOT TURN ON AT ALL
My CTC195 Rca Series Tv before I turned it off the picture on it was curved & colors were blurred & now it will not turn on at all..What can be wrong with it? Thanks for any help
    President:
  • 3,130 Answers
The fact that the picture was curved tells me that the pincussion circuit was faulty. If your not a tech then your gonna have to get a pro to assist you with this repair as everything is soldered in and theres no user replaceable parts in this set as they are all soldered in. If you know electronics then the most common parts for the set being dead would be the hi-voltage transformer and the horizontal output.. Also the small coil l401 has to be resoldered. Now for the pincussion circuit you gotta check waveform on base of tl81 for 13.7 vpp and if its not there replace IL81 and RL81. If its is there then check the transistor TL81 and TL82 & CL85. Im sure you will find on of them to be bad. Lke I said if your not a tech you can get a bad shock piddleing with this set. Good Luck
Posted on Jun 30, 2006
SOURCE:
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | RCA P46924 46" Rear Projection Television
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
TV is just beeping no picture/sound
I have looked through most of the answers to the same problem question and found my answer. I thank you very much for your site for the free info as the cost could have been huge to fix it. Now that I no the part the cost is minimal, and I can do it myself(with a little help from my friends).
Again Thank You
Kim Graziano
Jan 31, 2009 | RCA P56923BL 56" Rear Projection...
RCA 60" Rear Projection TV Model P60925bl TV screen curved on the top and bottom. Colors are not aligned and images are blurred.
this would be the convergence IC 's that need replacing
if you are going to have a tech come out to do the repair it will cost between 3 or 4 hundered dollars
if you are going to do the repair yourself ( meaning that you can solder and indentify the convergence chips and test the resitors on it) then it will cost about $40 or so
electech
Nov 27, 2008 | RCA P60921 60" Rear Projection Television
Rca tv wont turn on
What is your Chassis# and what year is TV??
Nov 18, 2008 | RCA P56950 56" Rear Projection Television
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA F32450 32" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
