Question about Toshiba Satellite A25-S207 Notebook
CPU saturatuon. I upgraded to 1g with two 512mb chips. I thought this would take care of the problem but the WINDOWS TASK MANAGER still shows the CPU usage, much of the time, over 100% (saturated).. Of course this a serious problem in speed. Your advise would be greatly appreciated. capttom888@aol.com
You'll need to look at the Processes panel in the Task Manager to see which processes are consuming your CPU cycles. If you click on the CPU column heading, the process list will re-sort based on CPU usage. If the list appears to be arranged low-to-high ('00' at the top), click on the heading again and the list will reverse so that it appears high-to-low ('00' at the bottom). Once you identify the contributing processes, you can troubleshoot them one-at-a-time.
Posted on Oct 20, 2008
I have a Dell B110 and the system only recognizes 252Mb of memory. I thought I had a bad memory stick so I installed 2-512 chips. Now System Info shows the 1024 with only 100 available. Task Manager only...
Try to seat one memory first than try the other one. One of them might be defected. Also check the memory slots, ensure they both work well.
I had 2-512mb sometime system just detect 512 and other time 768. Since I replace both with new memory cards they work just fine.
Apr 13, 2010 | Dell Dimension™ B110 PC Desktop
Tip
Computer CPU/Processor maxed 100%
Is your computer experiencing a CPU that is running at 100% Is your computer experiencing slow performance?
You can view your CPU utilization and other performance stats using Windows Task Manager. Press Ctrl + Alt + Delete and bring up Task Manager. Go to the performance tab.
The top of this screen should show your CPU stats.
In Linux you can use the TOP command,
Type the top command:
$ top
A CPU that is running at 100% utilization is not necessarily a problem. When the computer is booting up, or coming out of sleep mode, it may max out the CPU which is normal. The CPU will be utilized fully in order to bring the computer up as fast as possible. Some computers will even utilize the CPU while it is idle, to complete background task such as disk cleanup and file reallocation.
A problem will occur if the CPU stays maxed out. If it stays at 100% for more than a couple of minutes, you may be experiencing degraded computer performance.
Steps to reduce performance degradation.
-In a limited number of cases, software bugs can cause CPU utilization to spike. You will know this is the case if you are using a computer program(that is not hardware intensive like photo/video editors) and notice degraded computer performance. Check your CPU stats while running the program. If this is the case, check online for solutions and possible upgrades which resolve bugs in the software.
-You can reduce Windows start up programs, which will speed up the boot/wakeup process. You can do this from the MSCONFIG window. Go to Start > and in the run box type "msconfig". Go to the "startup" tab and you can uncheck which programs you do not want to start with Windows.
-A majority of the time a computer will get to a point were the hardware will need to be upgraded in order to handle the work you are doing. Common computer upgrades are memory, cpu, motherboard and hard drive.
-G33k
on May 15, 2011 | Computers & Internet
Trying to ugrade the ram from 512Mb to 1G. Once
mem needs to be installed in pairs, ie two 512 chips
Sep 07, 2009 | Sony VAIO K45 Notebook
RAM for AVERATEC 3120V
Max for this form factor is 512mb. It can be upgraded. Here is step by step instructions
http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Notebook/Max..ing_Out_Memory_on_the_Averatec_3120V_Slim_Notebook
you can buy the ram here for about 18 bucks with a credit card and free account setup
http://cgi.ebay.com/Viking-512Mb-PC13364X64CL3-512MB-PC133-SDRAM_W0QQitemZ120445441132QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b1b946c&_trksid=p3286.c0.m14
Good Luck! Your Amigo!
Ruben
Jul 28, 2009 | Averatec 3120V Notebook
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Problem about task manager
open the task manger
select view
select CPU
choose a graphic for the CPU
if you have dual CPU, you need a setup for each CPU.
as far as OS serial key. the windows Xp or newer OS detect the machine model. (manufacture embedded the comparability hardware serial.) then you can just activate the OS online.
THe older machine must have a legal copy of the OS. activation is not possible if the OS is counterfeit.
Dec 05, 2008 | Microsoft Windows XP Home Edition
Greetings..I just purchased a lexmarx series 3600-4600 i have win xp sp2.. and with 254 MB I get a message installing the driver i need 512MB. Is there a driver to allow me to use this without bogging...
Hi dhunting2000,
I am afraid that you are going to have to upgrade your memory on your computer to use that printer. (There is not any slimmed down versions of the software available), I personally recommend upgrading your computer to 1G of memory to give Windows XP (and the printer software/and other applications) some breathing room for best performance. I think you will be pleasantly surprised at the performance gain that you will get with 1G of ram versus 512M.
Hope that helps,
Take care,
Michael
Nov 16, 2008 | Lexmark Office Equipment & Supplies
Memory upgrade
It looks like the A25 will only hold 1g of PC2100, which is really plenty, unless you're a serious gamer or into graphic arts and need an extreme high definition video. Here's a link to the memory configurator that I use in order to find the proper memory, max held, and the chipset. You might double check to be sure I looked up the right machine. If it is the right machine, I suggest two 512mb chips. Sometimes you can't run one 1g chip because the slots are designed to only hold a certain amount, and if they will hold the 1g chip, sometime the machine doesn't run properly. It wants to use both slots accordingly, running only one creates conflicts. This should help in boosting your RAM.
Aug 26, 2008 | Toshiba Satellite A25-S207 Notebook
IBM thinkpad g40..i want to upgrade
To upgrade your CD drive there is a screw on the bottom of the machine that holds it in place. Remove this screw and the drive will slide out. I buy most drives for my customers and shop from Ebay. I've found that there are some very good vendors with good prices and warranties there. Now for the memory. The memory you need for your machine is PC2100, and 1g is the max. I mainly use Kingston or Infiniton. Both of these are good chips, and there are other good chips out there. I suggest that you use two 512mb chips that are the same make. I've found that sometimes two different chips will create a conflict with each other. The memory is located under a panel on the bottom of the machine. For memory I use pricewatch.com If you have any other questions please fell free to ask.
Jul 21, 2008 | IBM ThinkPad G40 Notebook
P23g PC Chip Mother Board and DDR2 Ram
probably your motherboard does not recognise the faster ram go to BIOS setup and check ram is set for auto
Jul 17, 2008 | PC Chips P23G Motherboard
Toshiba Satellite A25-S207 Notebook Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
