Question about Bissell 1695 PowerSteamer Vacuum
It doesn't **** the water up and i'm not seeing any steam
  • Anonymous Nov 30, 2008
    we haave the same problem,, found a split hose when u lean back up right part,,,found a split hose, so losing sucktion,,,but can't find hose part anywhere "":???? help thx
  • torkz8 Nov 30, 2008
    have the same problem,,, found a split hose between the upper and lower section,,problem is can't find the hose anywhere,,,
I went to the hardware store and bought a foot of non-colapsible hose and two stainless steel hose clamps (taking the "airbox" with me as a guide. The airbox is the rectangular box at the front end of the hose and it does come off the base unit. The unit only needs about 7-8" of hose and the clamps have to go on TIGHT, as the hose will be slightly oversized. I used Plumber's Putty around the inside of the hose to help ensure a seal but you can use other sealants, like silicone. Just give it time to dry before use, at least a day and perhaps two. Use of the clamps is a tight fit and you will have to remove other components to install them but everything will fit.
Posted on Dec 26, 2009
  • hfheard Dec 26, 2009
    In addition it is not a "steamer" type of carpet cleaner. The water is only as hot as the water you put in.
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam is coming out. the orange light is on.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Jun 14, 2011 | Vacuums
My steam vac is leaking water. It still works, but how do I fix it from leaking out the bottom?
It cost me $65, had to buy a new clean water bucket. If you shine a light on the bottom you will see a shatter effect much like broken shatter proof glass in car windows, apparently it is cheap and doesn't last. Who knew?
Jun 10, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Shark steam mop will not syeam grey pruple shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam buggy water reservoir cap has apparently been cross threaded, and cannot be removed by twisting or other "encouragement." If I cut it off, where can I get a replacement? Can the machine be used as...
You need to completely annihilate the plastic cap by cutting it off and destroying the remaining plastic to expose the stainless steel insert/plug. You can use either a pipe wrench or 11mm wrench to turn the insert counter-clockwise to unscrew. You will need to use some force to get the plug out since it's basically glued shut by lime deposits in your tap water.
Do not move the slotted cap or else this will need to be adjusted so that all your water doesn't squirt out before turning to steam.
Next time only use distilled water. Store with the cap off. Grease the inner and outer threads after every use and wipe it off completely before use so it doesn't mix with the steam and turn to vapor.
Sep 23, 2010 | Tristar SB Steam Buggy Vacuum
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell 1695 PowerSteamer Vacuum Logo
125 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
