Navman trackfish 6500 no display
My plotter / fishfinder which was working ok sudenly stopped displaying any information only get vertical lines across the screen. I use a through hull transducer which appears to be OK.
  • 3422 Answers
The most common cause for the loss of picture is a bad Horizontal Output Transistor (HOT). but I would suggest you get a detailed estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system has failed. There are over 100 components in this section and any one of them, or most of them can be at fault. However, the most common failure is the VOT or vertical output transistor (which is often buried inside a chip).
The repair will cost around $250 plus or minus.
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair..
Posted on Feb 21, 2008
SOURCE: Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
SOURCE: Vertical lines on LCD screen after taking shot.
put the camera in the hearse and take to cemetery and then go buy a new one , you cant take all the money you made with you.
Posted on Jul 04, 2009
SOURCE: i need a manual for Navman trackfish 6600
I need a manual for a Navman Trackfish 6600. Can i download it or where can i purchase it from?-
Posted on Apr 06, 2010
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
While out on the water my hds 5 suddenly started to display incorrect information such as water temperature and depth. There is no visible damage to the device and I have sprayed contact cleaner in the...
First try to clean the interior, removing all the contact spray. It will cause the metal parts to oxidise If you see oxidised parts or contacts, try cleaning those parts. Also check if the contacts of your cabling are still free of dirt and oxide.
Take care don't clean with sharp tools, because toy will damage the contacts, bend repair.
Jul 17, 2014 | Lowrance Hds 5 Hds5 Fishfinder gps Chart...
Samsung 6000/6500 internet browser
The 6500 and above has a web browser in the Smart Hub else:
Using Your TV as a Computer (PC) Display
Setting Up Your PC Software (Based on Windows XP)
Depending on the version of Windows and the video card, the actual screens on your
PC may differ in which case the same basic set-up information will almost always be
applied. (If not, contact your computer manufacturer or Samsung Dealer.)
1. Click on "Control Panel" on the Windows start menu.
2. Click on "Appearance and Themes" in the "Control Panel" window and a display
dialog-box will appear.
3. Click on "Display" and a display dialog box will appear.
4. Navigate to the "Settings" tab on the display dialog-box.
The correct size setting (resolution) [Optimum: 1920 X 1080 pixels]
If a vertical-frequency option exists on your display settings dialog box, the correct value is "60" or "60 Hz". Otherwise, just click "OK" and exit the dialog box.
Oct 10, 2012 | Sys Refurbished 6000/6500 (wsx6101oc12sfm)
G-Pilot 3100 Autopilot
Go to and they have display repair kits for the Navman Instruments.
Apr 03, 2010 | Navman F3100 DISPLAY ONLY AA002611R GPS...
Trackfish 6600 will not receive satalite and
moisture and oxidation, neither work well with any electronic devices . many can never be repaired to work due to this .
Sep 14, 2017 | Navman Trackfish 6600 GPS Receiver
No gps fix NavMan trackfish 6500
my navman trackfish 6600 gps is aquireing and will not give a gps fix ,I have also had the screen ghosting when I enlarge the area with no detail, the unit is 4 years old .
May 09, 2009 | Navman Trackfish 6600 GPS Receiver
I need a manual for Navman trackfish 6600
Dec 30, 2008 | Northstar Explorer 660...
Navman 5500 tracker
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
54 people viewed this question
