Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool ED5FHEXSS02-need to get to pan under the freezer
I had a leak in my freezer and need to get to the pan that is located under the freezer.
  • westin Oct 20, 2008
    I had a leak in my freezer and need to get to the pan that is located under the freezer....Whirlpool ED5FHEXSS02
  • thepinkster Oct 29, 2008
    Me too, but can not find a way to get to the pan!
  • 111 Answers
SOURCE: WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Posted on Dec 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
  • 236 Answers
SOURCE: water pan inder freezer is full & leaking water
it may be that your defrost drain hole is blocked at the back. check it out but runnin a flexi band down it. if its the freezer drain hole you will need to do a full defrost to unblock ice.
Posted on Mar 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator leaking water on floor under it!
The leak is most likely coming from the defrost tray below the evaporator coils. A piece of ice or something is preventing the water from draining to the pan below your refrigerator. Unplug and remove the back panel inside the freezer. Any blockage from that tray will cause the water to pool out into the freezer or fresh food section. Thanks, Sea Breeze
Posted on Jun 18, 2009
MNfisherman
  • 11896 Answers
SOURCE: Water leaking from behind ice chute door & freezes under ice bin
You will have to remove the unit and access the rear of freezer. Check that the filters are not plugged as well as drain.
Posted on Jul 20, 2009
How do I remove the drip pan from under the freezer? It's full and leaking onto the floor?
There should be a decorative kick panel underneath that will snap out revealing the drip pan which will then slide forward and out to pour the water off.
Nov 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator has water running down from under freezer and there is no water in the drain pan.
Your drain line is clogged from the freezer to the pan. The drain line and drain pan are located behind the back freezer wall panel.
Aug 09, 2011 | Whirlpool ET1FHTXM Top Freezer...
New whirlpool ED2GVEXVD side by side. Water leaks onto floor periodically. Water coming from door is not cold. Also, it is noisy. Any fixes
HI,
Recently, I ran into a wave of broken drain pan for the defrost water. When this occurs, the water leaks out on to the cardboard under the unit, causes the card board to warp and come in contact with the fan motor to cool the compressor. If this is so, you can either replace the pan or seal the pan with tape to prevent it from leaking. I have also notice the water valve is located above the drain pan too, if you have a leak it will over fill the pan causing the same problem. Those are the two easiest places to check first. You can remove the grill from under the doors and use a flashlight to see if water is under unit.
Lastly, is there water on the freezer floor? If so the could be a clogged drain tube in the freezer section.
I hope this points you in the correct direction..
Jul 27, 2011 | Refrigerators
Drain pan filling up. I emptied the pan and about 24 hours later its full again. We have ice and water in the door the freezer is cold just pan filling
If your evaporator fan is working properly the water would evaporate back into your home or business. If the evaporator fan was not working the freezer would not freeze and fresh food would spoil. That is way too much normal condensate unless there is a leak around the door seal or leak in the cool water supply tank storage or filter area. Not knowing the model number I would think you may have a drain opening under the crisper drawer that leads to pan. And think it may be a good idea to turn water supply off until sure of the source. Click here=> Leaking Refrigerators Just What may Be Happening and Click Here=> Leaking Refrigerator's? Locate model number for Kenmore Here=> Kenmore Model Number Locator's Most other model number locators are about the same as on the left sidebar on the Leaking Refrigerators page. I will be here to answer further questions, and there are a lot of things to look for on that page, Thanks, Sea Breeze Click on Logo enter your model for parts breakdown=>
sea_breeze_114.jpg WHIRLPOOL PRODUCT MANUALS
I will be here to answer further questions, Thanks, Sea Breeze
Mar 13, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the pan where the water drip into
Hi, well the pan you are referring to is called the "drip pan" pretty clever huh?lol well this is located underneath the unit most commonly under the freezer side towards the back. To find it you can pull the fridge out from the wall and unplug it. Then remove the cover panel for the compressor and sealed system. When you remove this panel you will be able to see the drip pan under the freezer. Im assuming you are needing to find this because it is leaking. That is a very common problem due to the pans being made out of plastic and being exposed to temperature changes will sometime cause it to crack. I hope this helped you in any way. Please give some feedback.
Jan 07, 2011 | Whirlpool GS5SHAXN Side by Side...
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS ONTO TOP SHELF AND UNDER BOTTOM DRAWER
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Jul 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking on inside - top shelves
The drain for the freezer is clogged. Unplug the frige and let it defrost. Pull the cover from the bottom front and note the drain pan. water should start draining into pan as the freezer defrosts. If Not the drain may be blocked. To access the drain remove icemaker then rear panel of freezer carefully, unplugging fan and ground wire. Look for drain in the middle under the coils. Look on outside back for the drain hose, this will help you locate the drain. Clear the drain of ice using hot water. You will hear it drain down the drain hose to the pan below.
Mar 29, 2010 | Whirlpool Refrigerators
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
159 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
