Canon printer pixma ip2500 continually flashing paper jam no paper jam visible
  • 1 more comment
  • einsteinfx Nov 30, 2008
    paper jam message is flashing every time when i give a print. but there isnt any paper jam.
  • Anonymous Dec 19, 2008
    GIVE IT A GOOD KICK
  • mikelcuk Jan 08, 2015
    Pushing A4 card through worked!!!
  • 29 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
  • 52 Answers
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Posted on Jan 23, 2009
  • 117 Answers
SOURCE: canon pixma ip1980 service error 6000.. it flashes
your canon pixma paper jam open the printer caling
Posted on Oct 07, 2009
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
http://www.fixya.com/support/t119769-false_paper_jam_warning_canon_pixma
To my surprise, it worked perfectly... and was great stress relief.
Posted on Oct 22, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
My Canon ip 2772 Printer does not works. It says Error 6000. What Can i do? there is no paper jam in my printer. Plz Help
Try these:
Solution 1:
  • Verify that the paper tray is correctly set.
  • If any object is placed in front of the machine, remove it.
Solution 2:
  • Search for any small pieces of paper in the printer, or a tiny object.
Solution 3:
  • Power off the printer
  • Wait 5 minute
  • Power on.
Solution 4:
  • Clean the encoder strip with a soft cloth
Solution 4a:
Jun 01, 2015 | Canon Pg40 Ink Cartridge for Fax Jx200,...
My Canon MP480 says the paper is jammed when in fact it is not. how can i reset it?
Turn off the printer.
Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it
Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance or repair.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Mar 04, 2014 | Canon Pixma MP480 All-In-One InkJet...
Ive just turned on my Canon pixma mp250 printer and have an Error, the screen is flashing E 0 3??? have tried resetting but that hasn't had any affect.
An E3 error code in a Canon MP210 printer is frustrating. This code reflects a paper jam that is not always apparent immediately and can be indicative of other problems.
Remove the jammed paper by pulling it from the front or top of the printer. If it does not come out, restart the printer to eject the paper. If the paper fails to come out or rips, remove the cover and retry. Once you have removed all visible paper, check paper sensor paths for debris or damage, blowing it out as needed.
Reload the paper as recommended and print a test page using the printer's software. If the error continues, the sensor that generates the error may be damaged. If so, take your printer to an authorized service center.
Aug 31, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Orange light flashes 5 times continuously on canon pixma ip4300
Orange light flashes if there is any issue with the printer. Please check all the hardware is functioning properly. Check if there is any paper jam. If printer cartridge is installed properly. Printing head is ok.
Dec 09, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Why is the orange light on my Canon IP5200 printer keep flashing?
make sure all the catridges are proper and there is no paper jam inside in the printer.
Jan 14, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Printer jam
Its probably somethnig in paper feed path.
Use flash light or just start to shake printer it may come out
Jan 12, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I install the printer cartridges in my canon ip2500?
Download Software IP2500 zip-file for the IP2500 on next site :
http://software.canon-europe.com/software/0032509.asp?model=
Select PIXMA iP2500.zip on the bottom page for the complete download ( 110 MB ) for this printer.
Oct 31, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Printer jam
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-10
Jul 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
320 people viewed this question
jasbo
jasbo
