Question about HP Computers & Internet
Installation of HP 3055 fails. Error Situation Code: 24016973.
4 Suggested Answers
  • 47 Answers
SOURCE: Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Posted on Nov 22, 2008
marlen56
  • 110 Answers
SOURCE: PCL XL error in hp laserjet 3055
information about the cause:
PCL XL error pages that print from an HP LaserJet 1200, 1300, 2200, 2300, 3200 or 3300 series product when a PCL 6 printer driver is in use typically indicate a communication issue. Sometimes this issue is caused by an incompatibility between the Enhanced XL language and the software application.
You can find the solution for this error here:
(It's a long instruction page, I advise to copy the sections that refere to your OS to a separate document, so you don't miss any step)
URL to HP service page:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1161389&prodTypeId=18972&prodSeriesId=1161389&objectID=bpl10637
Posted on Aug 29, 2009
OK, here is my debugged/tested solution.
I know your error refers to a different installer MSI file (CIOUM32.msi) but the installation component in your log file (ipm12.A4B24390_80AD_4BAF_B8FD_C670FE0DB586) is identical to the one that was giving me trouble as well (i.e. points to the same service/file). So it is definitely worth a shot to try this solution out as it will only take a few minutes.
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Posted on Oct 30, 2009
50 fusor error code for hp 3055 copier printer
Fusor needs to be replaced or error in Fusor section of main board
Jun 01, 2015 | HP Office Equipment & Supplies
HP LaserJet 3055 All-In-One Printer "49 error turn off"
The 49 code is related to one of three things on this unit.
1. You accidentally used a refurbished toner instead of one directly from the manufacturer which tends to cost a bit more. The certified one from the dealer is known to clear this error code instantly.
2. Your internal memory cash will need to be reset
3.You have internal hardware failure which can not be repaired by the user and must be sent to the manufacturer.
Mar 22, 2013 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
SOLUTION:
Steps:
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
Error code is 2753
Error #2753 is not a real code number for the HP 3055!
Please Visit here to check any other error codes regarding this machine here;
http://h10061.www1.hp.com/ccsearch/search?pname=HP+LaserJet+3055+All-in-One+Printer&qry=error+code+2753&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1140780&productBigSeriesOid=12012&spid=1140612&opname=HP+LaserJet+3055+All-in-One+Printer&pname_desc=HP+LaserJet+3055+All-in-One+Print%2FScan%2FCopy&ptype=commercial&stype=pn&contextual_lname=&spname=HP+LaserJet+3055+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&search=0
Good Luck!
Rich Lilja
Nov 13, 2008 | HP LaserJet 3055 All-In-One Printer
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Error 2753 HP3055
My Scenario:
Exit code=1603
BACKGROUND:
CAUSE:
SOLUTION:
Steps:
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
My Scenario:
Exit code=1603
BACKGROUND:
CAUSE:
SOLUTION:
Steps:
Dec 08, 2007 | HP LaserJet 3055 All-In-One Printer
Computers & Internet Logo
396 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
