Speaker does not work
I formated the system after that my speaker does not work
  • Anonymous Jan 13, 2009
    I need a driver for my speakers
  • 728 Answers
You may have to delete and reinstall the software. Try not to format the system anymore if possible because when you format your system, your'e making the software where it can only work with the computer and nothing else. That means that when you plug the speakers in, the software won't recognize them.
Posted on Oct 22, 2008
BH7520TW cordless rear speakers not working
if you having this problem when playing music, this is perfectly normal 'cos music only gets played through 2 speakers (2.0 audio format)..if this happens when playing a movie, you have to check if the movie (through the disc menu) is in 5.1 audio format which is surround sound through all the speakers..
Feb 10, 2013 | LG Audio Players & Recorders
LG HT355SD only 2 speakers work
It's normal for only 2 speakers to play if you are playing music or if the movie you are watching is not in Dolby Digital 5.1 format..
Dec 21, 2012 | LG HT355SD DVD-Home-Theater-System
Rear speakers not working after formatting the system. Please. Help.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 06, 2012 | Audio Players & Recorders
Center and rear speakers not working
In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
Jun 26, 2009 | Audio Players & Recorders
I have plugged in my speakers at right place but no sound is coming out of it. I also have a sound card of realtek nothing is helping. Please provide some solution.
Try changing the setting from the "Realtek HD Audio Manager" Select the correct input jack, double click it then "Which Device did you Plugin " window will pop up select the appropriate option and shall work. If this Does not work disconnect the speakers from the system, remove the sound drivers & reinstall it again, connect the speaker. This shall work now
Jun 25, 2009 | Ozaki DT-500 3-Piece Speaker System...
I had to reinstall Windows Vista. When I did so my computer lost a significant amount of volume output from both the speakers and the headphones. I have tried increasing the decibel output on the mp3 files...
The format shouldn't have made a difference with the system volume? Try to Reboot PC, and when windows appear, hit F8 key constantly until you here a beep. You are now in the Repair/safe mode/system restore. This is where you need to perform the system restore. This should work..
May 17, 2009 | Microsoft Windows Vista Home Basic Edition
Creative Inspire T3030 speakers not working
hello
I have creative inspire T3030 ,dont function ,Iwant help
Mar 31, 2009 | Creative Labs Inspire T3030 Computer...
Connect Altec Lansing ADA745 to HD TV RCA output for home theater
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
Feb 25, 2009 | Altec Lansing Multimedia Computer Speakers
Speakers stopped working
you should format and reload that system
Feb 16, 2009 | Dell Dimension 2400 PC Desktop
66 people viewed this question
 Grubhead
Grubhead
