Question about Lands Phones
Iphone shows emergency call only no home menu
  • teslaCo Mar 31, 2009
    I have the same problem
  • Anonymous Apr 06, 2009
    This has happened twice in the past week. If I shut down the iPhone and then start it up again, it behaves normally.
My iphone shows the itunes logo on the screen and when u slide the botton u can call the emrgency call only
Posted on Apr 30, 2010
When turned on, iphone disabled is displayed and only emergency calls can be made
plug the iphone to your computer (make sure you have itunes installed in your computer) turn the iphone off once plugged. Once its turned off, press the power button and the home button at the same time, hold it for around 10 seconds but continue holding the home button. on your computer (itunes) it should show up a message detecting the device (iphone) just press ok and it will bring you to your itunes home screen--from there CLICK "RESTORE" and that will enable your iphone again
Aug 23, 2011 | Computers & Internet
How to unlock emergency calls model iphone 3G A 1241 its showing lock code
  1. Connect the phone to the computer
  2. Hold the home button for 5 seconds and then while holding the home button press the power button until the apple logo appears, then let go of the power button but don't release the home button.
  3. open itunes and click on the iphone on the left pane
  4. click the restore button on the window with the iphone's information( this will erase all your data including apps, contacts, songs, videos, etc)
If you need any help watch this video
Feb 17, 2011 | Apple iPhone 3G
How will i unlock a password on an iphone with knowing the phone number
If you are faces with a password protected iPhone, you can still unlock and access iPhone favorites, address book, dial keypad, and voice mail. This trick is not a high tech technique, but just a simple unlocking steps to do. This simple steps can be done because iPhone has the security flaw. Gizmogo posted this steps like the followings:
Try to slide to unlock, tap emergency call, after that, double tap the home button.
Whoola, you will find yourself in iPhone favorites. From there, you could access other menu like address book, dial keypad, and voice mail.
If you are the owner and wants to avoid this security flaw, you could do the following.
1. In the iPhone home, go to Settings.
2. Click on General.
3. Click on Home Button.
4. Click on either "Home" or "iPod".
By doing this, when someone is doing double tap, he/she will be redirected to the unlock screen (if you choose HOME). Good luck.
Dec 19, 2010 | Apple iPhone 3G
Home button not respon
It may be a broken menu button contact, broken menu button or (less likely) broken logic board. If Apple doesn't replace it for you, you can find the menu button or screen module on Ebay or at iPhone 3GS Repair and there is a guide that shows you how to put in the part at iPhone Repair Guide.
Nov 26, 2009 | Apple iPhone Smartphone
If iphone was stolen but password protected. How many attempts do they have to try to get in before iphone is disabled. Also, if they try to restore via computer and don't have same computer I have, will...
This only works if you have the older versio of software installed. This trick is not a high tech technique, but just a simple unlocking steps to do. This simple steps can be done because iPhone a flaw. Try to slide to unlock, tap emergency call, after that, double tap the home button, you will find yourself in iPhone favorites. From there, you could access other menu like address book, dial keypad, and voice mail.
4. Click on either “Home” or “iPod”.
OR TRY THIS
U can get rid of the password by putting the iphone in restore mode. Once in the restore mode, you can connect your iphone to itunes and phone in restore mode menu will pop up. Click ok, and hit restore . This will reset your iphone and all of your contents and the iphone will be back to its original factory settings.
You can put the iphone in restore mode by holding the home and power button at the same time (sometimes it only works if u hold the power button at first and then hold on to home button)
Nov 24, 2009 | Apple iPhone 3G
I've got an complication with my apple iPhone 3g model-a1241. that is when i insert sim after that i am unable to go to main menu.and only allowed to do emergency calls. how shall i proceed?????
my guess is ur using for the first time and cannot boot in to home screen ... and instead shows the emergency calls only option ...
my friend ., either ur phone is not properly jail breaked ...which s\w or firmware version are u using ?
and where did u buy it from ., dont say ebay ! as chances are can be a total fake (looks exactly the same )...
reply to be and please provide more info ., i am willing to get to its roots and probable get a fix for u....
Oct 26, 2009 | Apple iPhone Smartphone
My iphone is only available to make emergency call,Waht can i do?
Its show that iam connected to ITUNES and the only thing that i can do is make emergency calls.Please help with this situation,also my iphone is connected to T-Mobile.What can i do to fix my Phone.Thanks in advance.
Jan 31, 2009 | Apple iPhone Smartphone
Can't Reset to preactivated factory stage(emergency call screen?)
go to itunes. when plugging in to computer hold down the home key it should restore factory settings. i called apple.
Dec 26, 2008 | Apple iPhone Smartphone
Lands Phones Logo
1,966 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
