I needed to repair a canon MV600i camcorder with a new board. I did this and after re attaching the ribbon cables and other cables all carefully as not to break them the unit would not power up again. At first i thought it could be a faulty spare board but it did the same when i switched the old board back. I havent missed anything obviouse that i know so where am i going wrong??? Any help would be amazing or a service manual if anyone has one.
If you are absolutely sure that you have all cables hooked up and hooked to the correct plugs, and also you know positively that the battery or power source is putting out the proper power, then I would suggest that you look at each cable again and make sure that they are inserted fully and correctly. By correctly I mean to look at the ribbon cable when it is removed to determine which side the metal contacts are on. The cables which push in only have metal tangs on one side. The cable plugs only have metal contacts on one side also, usually the part which does not face the board. It is a common mistake to face the metal side of the ribbon cable towards the board (you would think they would be designed to go that way). This would be wrong in most circumstances and would not allow the signal to pass. Connectors which require you to lever up a lock away from the board usually hook up opposite to what I just described. That is why I say to check each one again. If you look at each ribbon cable you can determine which side has the metal tangs, then look at the plug and determine which side has the metal contacts, match the two together and you have it. Removing each ribbon cable, checking for proper orientation, and reinserting fully should solve your problem if you have truly not missed any wires. I find that a little bit of electrical cleaner on the cable end makes the wire insert easier and less chance of damage as well as hopefully cleaning any oxide off the connectors on the way in. Good luck.
Hi
Also I've disassembled my mv600i, in order to fix the 'usual' trouble of black screen . Fortunately CCD was good, but several contacts were dirty! . I've cleaned any contact and the printed boards, using a suitable dry spray (without oil) and my camera is working again.
It's very important cleaning contacts and circuits from dust, dump and other, 'cause high impedance Mos circuits are very sensitive and can block the device. I've a lot of experiences on this matter. Many devices using Mos technology may be afflicted.
Regards
Donald
I was rewinding a tape, it had a good battery with loads of power and was connected to the mains and...
(More)
I was rewinding a tape, it had a good battery with loads of power and was connected to the mains and it just stopped mid-way through rewinding and 'died', no power, nothing, tried another battery, nothing, does not even recognise it is pulled into mains, is there anything I can do...other than throw out the window??! ;)
Can I download from my canon mv600i digital camcorder to my new laptop which has an HDMI port? (Acer...
(More)
Can I download from my canon mv600i digital camcorder to my new laptop which has an HDMI port? (Acer Aspire laptop)
Canon MV 600i. My cassette compartment fails to open. By sliding the eject switch this should happen...
(More)
Canon MV 600i. My cassette compartment fails to open. By sliding the eject switch this should happen automatically. However, the compartment simply comes out, doesn't open and simply returns without allowing old cassette to be removed/new to be inserted. Any suggestions. Thanks Jiten
