Question about Sony KP-53HS10 TV
KP-53HS10 Blinking light won't turn on
  • Sony Master
  • 5,568 Answers
This behavior may be the power supply but that may not be the actual problem.
Modern power supplies are designed to shut down if the current drawn exceeds the design level which indicates that something the supply services has died.
For gear made in the period of 2003-2006 and stock that is still on hand from that period, may contain electrolytic capacitors that have defective electrolyte, a chemical used in the manufacture of higher value capacitors.
The electrolyte was made from a stolen Japanese formula and improperly cloned in . . . where else? China.
There is no way to identify the problem parts besides the date code if present.
There are tons of electronic devices in service that will die due to this problem.
If you are adventurous, you might pull the plug on the set (allow at least a couple of hours), gain access to the innards, and with good light, inspect any boards inside.
You are looking for components that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many (not all) will show signs of pregnancy when they fail, bulging unnaturally when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
The important ones will be near a shorter, stubby, ferrite core transformer, not the tall one attached to the picture tube.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
Posted on Oct 20, 2008
Red light flickers and tv will not turn on , why
i may be able to help you,is red light blinking. if so how many times. it may blink like 5 or 6 times perhaps more or less then pause and cycle over
Aug 23, 2012 | Sony KP-53HS10 TV
Sony kp-53hs10 wont turn on blinking standby light only
This may be beyond fixing: see http://www.techlore.com/forum/thread/20738/Sony-KP53HS10-5-blink-repair/
Dec 04, 2010 | Televison & Video
I HAVE A SONY KP-53HS10
Hey Shannonbmomt I had the same problem with my KP-53HS10 and I had to replace the High Voltage Transistor IRFI640LFcost me about $20usd with shipping from
http://www.partstore.com/Part/Sony/Sony/872902430/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KP53XBR45
I also found that I had a bad flyback transformer which from what I have read online is also a common problem if the high voltage transistor goes out. So I replaced the flyback as well for another $18 from electronix.com part SONY FLYBACK 1-453-285-11
Soldered both pieces in and tv is good as new
Email or post with any further questions and ill see if i can help.
Mike
Feb 21, 2009 | Sony KP-53HS10 TV
KP-53HS10 blinking light
Ok I solved my own problem and posted the results here,
http://www.fixya.com/support/t1692655-sony_kp_53hs10
Mike
Dec 13, 2008 | Sony KP-53HS10 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
No video - Blinking code 5
yes im a tech unknown business i cant say what business or my name could lose my job but her you go, Fix the blinking light code 5 blinks turn down your picture vivid and your contrast ive makde plent of money fixing this issue for the company.
Feb 01, 2008 | Sony KP-53HS10 TV
KP-53HS10 has a blinking red light on
Try getting a new power supply. Replacement SOny flyback 859882800. That part costs $18 and would be the most inexpensive solution. Unfortunately your probably gonna have to do it yourself unless you want to pay huge handling/service fees. Just google the part number and it should come up. Part# : 8-598-828-00
SONY FLYBACK 8-598-828-00
Dec 19, 2007 | Sony KP-53HS10 TV
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
No picture
does the red light give you a blinking code pause then code?
Sep 13, 2007 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
