Question about Pentax *ist DS Digital Camera
My Pentax *ist* ds doesn't power on half the time!
Hello, I have a pentax ist that I recently received and it worked for a few days and then it decided to not come on at all. I switched batteries and that is not the problem. please help if you know what the problem is. thank you. have a great day!
  • 215 Answers
Check the battery contacts in the camera. Perhaps they are dirty and need a clean. Make sure you're not using Alkaline battereis and if you use rechargeables they are fully recharged and not getting too old to hold a full charge. Apart from that, without further information I can't help any more. BMW
Posted on Jul 02, 2006
SOURCE:
Hello I have Pentax IST DL just took out of case put new batteries in did not work battery light came on. Tried again came on but did not take photo. Then turned of again, tried lots of new battery. ...
The early ist cameras had a battery indicator problem which Pentax never addressed. Most owners learned to live with it by turning it off and on several times until it showed full power.
Dec 15, 2010 | Pentax Cameras
I want to obtain a larger memory card (currently have a 1GB) but everyone we buy I have been unalbe to get them to format/ I have a pentax ist DS
You should be able to use 2GB SD cards. Cards larger than 2GB are actually SDHC cards and will not work with this camera.
Oct 13, 2009 | Pentax *ist DS Digital Camera
Firmware install on Pentax ist DS. Had Ver2.0 & everything worked fine. Simply wanted to upgrade to V2.02 to used SDHC cards. User Power AC and install ran approx 90 secs and displayed showed half way...
You need to go to the support section of the Pentax website and engage in a live chat with a service tech using your computer or even a phone conversation to resolve your problem.
Oct 10, 2009 | Pentax *ist DS Digital Camera
*IST DS autofocus
Try using another lens, if this solves the problem you have a lens problem. If not the camera is the problem.
Jul 03, 2009 | Pentax *ist D Digital Camera
Using Pentax lenses from 35 mm on the digital camera.....
I have old Lenses that I use; you must set your lens to manual, Switch left hand front of body. That should resolve the problem.
Jul 02, 2008 | Pentax *ist DS Digital Camera
PENTAX IST DS PROBLEM WITH INTERNAL FLASH
First make sure the camera is not set to No Flash on the shooting mode dial.Also, in P, Tv, Av or M modes the flash reverts to manual and must be raised manually by pressing the button next to the viewfinder.
Jan 11, 2008 | Pentax *ist DS Digital Camera
Pentax *ist DS USB Cable
You need a Pentax USB cable I-USB17.
You can get it online from B&H photo or Adorama camera.
I would go with B&H photo personally.
Oct 26, 2007 | Pentax *ist DL Digital Camera
Flash won't work
Try in custom menu I think. Switch shutter release whilst charging firmware switch whilst flash charging a couple of times. Had sinilar thing with ist DS after firmware update.
Jan 08, 2007 | Pentax *ist DL Digital Camera
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Viewfinder
I don't know how to answer your question, since I haven't yet experienced that phenomenon. It sounds like it's just caused by the nature of the lenses used. Since you are new to the camera, I'll just warn you that it is not perfect in any way, but every function of it is very good, so the end result is amazing, and I might even say perfect. This is just the nature of the Pentax dSLR for now, and it seems that it's a Pentax thing in general. You'll find lots of dSLRs that can outperform the Pentax in one or two feature comparison tests, but if you lign up all the features of one camera and compare them with the Pentax you'll find the Pentax will beat any camera out there. It is just so well balanced, and each feature really is good enough, which adds up to a LOT. I'm sure somebody here will explain the problem you're having, and if you're like me you'll just make a few adjustments and be satisfied with the results. Post some shots too, that's an excellent way of getting feedback that will help you make the most of your Pentax. I wouldn't trade my Ds for any other camera out there even costing 10 times more.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Pentax *ist DS Digital Camera Logo
245 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
