Question about KitchenAid Dryers
Hello i have a kitchen Aide Gas drier Model number KGYS850LE1 serial number MA 4001331 , the drier will heat up for about 5 minutes then , the air becomes cool , the vent blower blows cool air ,and the drum still is turning ,i have ran the drier with the vent hose off and it still only heats for about 5 minutes ,the vent has good air flow ,the only way to to start drier to heat is to shut off control knob and restart drier ,then it will heat for about 5 more mintes and shut off ,thank you
  • 702 Answers
SOURCE: blower vents on 86 regal
The blend door in the heater box itself is what directs the air to where it needs to go as per selector switch. The heater box is located under the dash.
Posted on Jun 13, 2008
  • 104 Answers
SOURCE: Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Posted on Jul 02, 2008
  • 1450 Answers
SOURCE: Blower not blowing
can you hear the fan working on all speeds?
Posted on Sep 22, 2008
SOURCE: kenmore gas dryer after 5 to 10 min. later no more heat
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
SOURCE: gas dryer lgr 8648
Found the coils. Had to pop off the entire front panel. They were then easily reachable.
Posted on Jan 19, 2009
Heating poorly
You need your burner replacing, order on line, just goole your oven model, you will need your serial number, half price of buying from your gas fitter, mine was, it's a five minute job to fit for a gas safe plumber
Mar 26, 2014 | Rangemaster 110 (Gas) Kitchen Range
Hello, I have a Calvinator A410 unit that I am working on it is a heat pump, I had a leak remove freon and vacummed for around 5 hours. Having a problem charging the unit as a thermo protect on the...
There should be a name plate with the model and serial # which will tell you what the factory charge is for the unit plus 15 to 25 feet of line set. If you weight in the charge you should be pretty close...... In AC mode you should run around 125# suction and about 265 head pressure with 70 degree ambient F. If you have the right charge in the heat pump and you are still running 25# suction pressure in the Air Condition mode then you have a restriction filter drier or TXV locking up..... Did you replace the filter drier when you fixed the leak was the leak on the suction side if so then you definitely need to change the filter drier.
May 01, 2011 | Heating & Cooling
Location of the thermostat in a franklin water. Model F-5 Serial # 974-196
Hello, the model and serial numbers you have given has came up with no results anywhere. But, if this is a electric water heater, you will have 2- heating elements, and one will be the thermostat with a control setting. They will be found on the front face. You should have 2 panel covers that are screwed on. They will be behind the panels, and insulation. If you have a gas heater, the control at the bottom is the thermostat. I hope this has been of help to you.
A/C, Heating, & Refrigeration Contractor.
Also, Heavy in electrical and appliance trouble shooting.
Dec 17, 2010 | Heating & Cooling
Kitchen aide gas oven does not heat
good day,
hope this link below will solve your problem.
Jul 25, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help
Jun 24, 2010 | Kenmore 73932 Gas Dryer
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ or click
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
