Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
No water in my dishwasher
It  worked yesterday, but not now. I cleaned the filter at the bottom. I poured 2 kettles of water in the bottom and it immediately drained when I turned it on, but nothing sprayed and no other water came, nothing is spraying.
  • Frigidaire Master
  • 19,396 Answers
That is a problem with the water lever switch, that is actuated by a floating sensor. The floating sensor is probably stuck , and activates the drain pump immediately.
See here for more help There's no water entering the machine
Also check here for a general diagram: no water in my dishwasher - redarrow.gif Built in
Posted on Oct 23, 2008
Salt holder full of water
Hi Elizabeth
have had a dishwasher for many years and have found this to be a normal practice .... Hope this puts your mind at rest ????
Mar 20, 2016 | Dishwashers
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
The lining of the kettle on the inside bottom is boiling away. What is it made of and is this dangerous?
Stainless Steel doesn't boil away. What you're seeing is the mineral deposits (mostly calcium) left behind from heating the heavy water you're pouring into the kettle. Descale it, pour it out and rinse every month or when it gets bad if you like. These deposits won't hurt you but looks nasty. Another option is to use filtered water instead of tap water. Hope this helps a little...
Oct 17, 2011 | Oster 5965 Electric Kettle
Sediment is collecting in the bottom and on the dishes. I have tried a cleaning cycle but it doesn't work.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Maytag 24 in. MDBH750AWS Stainless Steel...
Water Laying in bottom of dishwasher
Usually there must be a filter screen in the dishwasher which can cause this to happen. It goes to the drain . If there is accumulation of food particles in the dishwasher filter screen then draining may be obstructed which can cause the water to be stranded at the bottom.
To exactly tell you where the filter is locate and how to clean it please specify the brand and model number of your dishwasher.Usually the filter is located at the back of the dishwasher near the drain. It is usually held in position by means of clips. You can just pop it out.Pour some hot water in the drain and clean the drain line also.
Feb 01, 2011 | GE Dishwashers
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
Whenever the dishwasher is started the drain pump stay on. It will only stop when the breaker is switched off.
Chances are you sump level monitor is stuck to the side of the drain with fat of other food substance that has got past the filter.
1 Empty your machine .
2. Remove the stainless steel filter below the lower basket.
3. Pour a kettle of boiling water down the hole beneath where the filter is.
4.Set the machine to rinse.
hopefully this will cure the problem
Nov 07, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Error code e4 on kenwood kdw12st3a dishwasher too much inlet wate
HI there,
I have had the same problem as most of you. I seem to have fixed it by
1. Bail out all the water from the inside
2. Remove the filter and 2 x mesh pieces.
3. Continue to bail out the water from the filter well.
4. You will probably find pieces of food or fat/debris in the bottom of the well. Remove these.
5. Tilt back the dishwasher at 45 degrees for 30 mins or so to drain and dry the flood sensor.
6. Boil a kettle and pour it down the well. Immediately put the dish washer on a eco wash (no tablets or anything) with half load (ie half water) and this will ease the water pump.
7. Let the dishwasher run its cycle.
8. Clean the filter again and the filter well.
It sounds quite long winded but with a £250 item you need to take care of it. Make sure you rinse most plates before loading in the future.
Hope this helps!!!
Good Luck!!!
neo
Mar 01, 2009 | Kenmore Dishwashers
How to descale Philips HD 4651/C Electric Water Kettle
Not having received any solution message from FIXYA contributors, I consulted with a family member
and also my long held Time-Life Books, Fix It Yourself Library, Volume: Cleaning & Stain Removal,
ISBN: 0-8094-7400-X, Copyright 1990. My issue was resolved by using white vinegar and soaking the internal problem area for 30 minutes. The appliance has cleaned up like new and works fantastic. I apologize for bothering you.
Nov 27, 2008 | Philips HD4651 Electric Kettle
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
802 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
