Question about Hoover F7431-900 SteamVac Vacuum
Hoover F7431-900 my carpet shampooer/steam vac was working fine until the brushes at the bottom of it just miraculously stopped working. they wont spin at all. Is this a motor problem? perhaps a water flow problem? please write back if you can be of any help. thanks
  • janan68 Nov 22, 2007
    Dang - this was a GREAT fix! My spin scrubber would spin when not on the carpet just fine, but when I put it back down on the carpet - it would stop or barely turn. I was looking and looking but just couldn't see the problem. I have been reseaching a buying a new cleaner for 2 days now & just had a random thought...maybe there's a fix - a new spin scruber or something...hate to spend another $200 on a new one. BINGO - just a clogged filter!!! I am not a "handy fix-it girl" - but this was really COOL. Thanks a ton!
  • 3 Answers
If the screen is not dirty, and the flapper valve to the turbine inlet is open, then the problem is mostly a stuck turbine impeller. The turbine impeller on my F7431-900 has seized TWICE!! The shaft for the turbine is not made of stainless steel, therefore is subject to corrosion. If you have a handy husband or boyfriend, give it to them, because some disassembly is required to access the turbine unit. After the turbine is removed and opened up, get some P'Blaster and squirt is on the shaft. P'Blaster is a rust removing solvent and is great for freeing up rusty nuts and bolts. Allow the P'Blaster 20-30 minutes to penetrate the corroded shaft. Then, grab the impeller and wiggle it back and forth, until free rotation is achieve. The last time my brushes stopped rotating, and I disassembled the turbine, it was really siezed up. I thought I was going to need to buy a new impeller assembly. But, that P'Blaster is really great stuff for breaking up corroded parts (it's like WD-40 on steroids!). I did need to give the turbine's impeller a good twist to free it up. If you can't get the turbine impeller to rotate, then buy a new one (about $27.00). Then, you can just install it and save a bundle on labor. I think I want to become a Hoover vacuum repairman. Their business must be booming because Hoover is putting out a poorly designed turbine unit. Boo, Hiss...... shame on Hoover for selling us **** like this.
PS You can get P'Blaster at any auto store, like Pep Boys, Autozone, etc.
Posted on Aug 28, 2008
  • 3 Answers
I had the same problem. Turned out to be so simple. Look down at the machine. On the right is the green spiral to indicate the wheels are turning. Right above that is a cover that can be popped off to allow access to a small filter. If the filter is blocked, air intake is blocked, and the brushes will not turn. Mine was clogged. Took the 2 seconds to remove the material and the machine was fixed!
Posted on Aug 04, 2007
There is a plastic cover on the bottom of the unit you have to remove. Two screws on the bottom and one in the top part of cover...squeeze in the ends at the back of the cover..remove it....Now llok at the spped control lever(off,lo,high) Did that plastic lever(with a slot in it) come out of the plastic button that suppose to go into the slot.If it jumped out,put it back in ( it is spring loaded.) This regulates the Off,Hi,and Lo positions. Sometimes when this lever lifts out of the connecting button, the spring loaded control arm will sometimes go the the "OFF" position,(Although on the machine it can say in "HI" position when it's really not,and therefore will not turn the brushes. KAPISH ?
Posted on Jun 02, 2007
  • 641 Answers
Open unit's bottem cover and look for the following: - Motor works - Belt which transfer motor's movment to the brushes, in place and not broken (most frequent phenomenon). - No mess on brushes axis which prevent their free movement. Good luck !
Posted on Jun 29, 2006
I have a Hoover Deep Clean carpet shampooer but can't find the instruction manual
Click on the following link and scroll down the list of Steam Vac models to find your specific one. Then click on the red characters which represent your hoover situated to the left of your specific model:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Best wishes,
Graemevm
Jul 03, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The brush attachment will not stay in place on my Hoover steam vac F5858-910
Check the bottom of your brushes. It should have a long shaft sticking out of of the middle of it which locks on the base. If you don't see the shaft, the brushes are broken
Jun 11, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Jun 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Problems with the Hoover Steam vac Heated carpet cleaner
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
465 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
