Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The Gear on top of the motor assembly is broken off. Is the gear assembly fairly easy to install????
Is the gear assembly fairly easy to install???? I can find the part at just about every web site on the Internet. BUT is it EASY to install with regular hand tools????
Chris
Boise, ID
  • 61 Answers
Of course is easy all u need is a hex screwdriver wrenches and thats it it will take 10 min to change it
Posted on Mar 10, 2009
Electic mirrors not retracting after one was knocked
More than likely the little plastic gears inside the mirror are broken or striped. I honestly wish the automobile industry would design a better electric mirror motor and gear adjustment system. Because it litterally doesn't take much at all to break of strip them. You will have to replace the motor and gear assembly inside the mirror, but it maybe easier to find a working mirror assembly in a savage yard. They are fairly easy to replace. Remove the inside door panel trim. Remove to two or three bolt the hold the mirror assembly to the door and unplug the wiring harness connector. Then reinstall everything in the opposite as removal. Hope this help.
Nov 28, 2012 | Cars & Trucks
Kenwood chef A701A mixer not working but blender does
could be one of three things
1) the belt is broken to the main gearbox (fairly easy to replace if you can get one)
2) a gear has slipped or broken which means none of the front end will operate.(I have this problem and cannot get the gear body to open)
3) If the top and front worms are turning then the problem is with the planetary gear which again is fairly easy to replace
Bill N
Apr 22, 2009 | Kenwood Food Mixers
Whirlpool quiet partner II top rack sprayer doesnt work
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Dishwashers
Top tray of Kenmore Quietguard3 dishwasher not cleaning!
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Apr 03, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is not washing dishes on the top rack...
HI,
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwaher does not clean, upper rack
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top spray not functioning in dishwasher
Mar 09, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
The upper rack doesn't not appear to get all the dishes clean. Why does this happen?
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Mar 05, 2009 | Whirlpool 24 in. GU3200XTPS Stainless...
Mar 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher not cleaning
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
67 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
