Question about RCA Cable Modem DCM315R (11603540)
RCA Cable Modem DCM315R Problem:
I am connected thru ethernet cord and every couple of hours i have to either reset the modem or disconnect it to stay on internet any sujestions ?
  • marx underwood Oct 28, 2008
    no router and the local cable co. npg is service provider
  • steelntz Apr 19, 2009
    experiencing the same problem with standard router
  • RCA Master
  • 2,794 Answers
Who is you service provider and do you have a router connected to it as well?
Posted on Oct 20, 2008
No router and S.P.is local cable co. npg
Posted on Oct 27, 2008
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
When I connect my modem to my laptop, all the lights come on except the pc link light. I have already unplugged it and reset it and it still doesn't work. What more can I do?
If the ONLY light not illuminated is your PC link light then that generally indicates a physical disconnect between the modem and the laptop. If you can get the PC link light to light up when connecting to any other device (computer, router, anything), then you are most likely looking at the ethernet jack on the laptop being burnt out. Otherwise, try swapping the ethernet cord. If a different ethernet cord does not resolve the issue and the PC link light does not come on no matter what the modem is plugged into, you are looking at a faulty ethernet jack on the modem.
Aug 17, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How can I install a wireless router to RCA cable modem DCM425 installed by Time Warner?
From the back of your modem, follow the ethernet cable to your PC (in). Mark or remember this location. Remove this cable from the PC and insert it into the INTERNET port on your router. Then take another ethernet cable (usually supplied) and insert one end into the ETHERNET port of the router, and the other end into your PC (where you originally removed it. Remember to check all connections and plug in the modem. You should now be good to go! If your PC has an installation Wizard, you can browse thru it as well.
Jan 07, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have a rca dcm315 cable modem a I can connect to the internet through a usb cable but not a ethernet cable. All I'm tring to do is hook up 2 computers to the internet and I just can't seem to get the...
When switching from USB to Ethernet (Or opposite) you have to unplug it, then hook up the Ethernet cable and plug it back in.
Please gave a vote (Rate our solution), it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Apr 01, 2010 | RCA Cable Modem DCM315R (11603540)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do I get into my RCA cable modem DCM315
For Me I Use 192.168.100.1 I don't know if that will work for you, but it might.
Apr 16, 2009 | RCA DCM315R Modem
1st and 2nd light Blinking forever!!!!!
http://www.amazon.com/RCA-DCM315R-30Mbps-Cable-Modem/dp/B00009UI2Z
read it!
Jun 06, 2008 | RCA DCM315R Modem
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Missing Modem RCA dhg525
Take the modem out and look for any brand names such as aztech etc and look @ the chipset to discern what kind of modem it is.
Dec 13, 2007 | RCA Cable Modem DCM315R (11603540)
Rca cable modem...
This one is for a DCM 315, it should be pretty close and might work. http://a1212.g.akamai.net/7/1212/6718/20030131/comcast.download.akamai.com/6718/help/cmdrivers/RCA_315.zip
Jun 20, 2007 | RCA Cable Modem DCM315R (11603540)
RCA Cable Modem DCM315R (11603540) Logo
627 people viewed this question
Top RCA Computers & Internet Experts
David Payne
David Payne
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
