Downloading and installing programs
Every time i try to download or install game from cd rom it comes up file or directory is corrupted and unreadable why ?
    President:
  • 2,017 Answers
Just run one command and see
go to run and type cmd then enter
then in document and setting otpion line
type chkdsk /r/f
he will ask u to resart the system just restart it and it will scan ur all files and make system proper.
Posted on Oct 21, 2008
Please insert correct cd-rom error in mohaa
Make sure the right cd, is in your drive.
Alternative (download a NO-CD crack)
Download from here: http://www.naxpgaming.com/gbw/dl.php?file=MedalOfHonorv1.0NoCDFixedexeUSEng.ace
Copy the mohaa.exe to your installation directory.
C:\Program Files\EA Games ..........
Jun 19, 2011 | Electronic Arts Medal of Honor Allied...
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
Installed game , go to play and error message pops up reading: Wrong Disk Inserted Please insert the original Gold Pack CD/DVD
Did the game come with more than once disc? You may have tried inserting the wrong disc.  If that isn't the case, you may need to download a crack for the game.
Go to this link:http://m0004.gamecopyworld.com/games/pc_sw_empire_at_war.shtml
And download the file that says "Empire at War: Forces of Corruption [MULTI] No-CD/Fixed Image"
Replace the .exe file in your game directory (normally C://Program Files/"game") with the one that the crack included.
Hopefully your game will run now!
Apr 26, 2011 | LucasArts Entertainment Company Star Wars...
My cd rom won't read some disc like the ones to install new programs but will read the games I all ready have installed what could be the problem and how could I fix it
try the following, it should help fix the issue.
Go to the link below.
http://support.microsoft.com/gp/cd_dvd_drive_problems
on the page that comes up. click on the green run now box.
It will start a file download ( this file is perfectly safe as its directly from microsoft)
Once you download the file, make sure to run the file..
It will run a dignostic program that will attempt to repair and fix your broken drive!
KittyTech.
Feb 20, 2011 | E-Machines emachines (emachinees) CD-ROM...
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
Problem when downloading file says installer integrity check has failed. common causes include incomplete download and damaged media. cannot install files.
If you're reading the file from a CD-ROM, then either:
* the CD-ROM drive is reading incorrectly,
* the CD-ROM is scratched, and thus cannot be read 100% correctly,
* bad RAM in your computer, that "corrupts" the data being read from the disk into the RAM.
Replace the CD-ROM.
Replace the CD disk.
Download "MEMTEST86+", and run it, to test the RAM; replace, if necessary.
Mar 26, 2010 | Computers & Internet
Receive cant find SIERA.err when i try to open my hoyle classic games
found this on the sierra support site, this was for king's quest, however it should resolve your issue as well ..
Problem: "Windows title not found" error when starting game, followed by "Cannot find SIERRA.ERR". (Windows 3.1 and Windows 95)
Solution: These error messages are caused by a corrupted or incorrect RESOURCE.WIN file. The RESOURCE.WIN is a small text file that contains information aout your computer. The game program looks at this file to determine where the game is installed and where to look for the game CD. If this file is missing information, you will get the above error messages. To correct this, edit the RESOURCE.WIN file (it's in the game directory!) and check that the first three lines look like this:
[Windows]
title=King's Quest VII
titleBar=TRUE
If these two lines are missing or show different information, add them or change them to match the ones above. Remember, they must be the first three lines in the file. Then, check that the last five lines look like this:
resAud=D:\
resSfx=D:\
patchDir=C:\SIERRA\KQ7
movieDir=D:\AVI
audio=C:\SIERRA\KQ7
These lines assume that King's Quest VII is installed to C: and that your CD ROM drive is D:. If your drive letters are different, make the appropriate substitutions. If these five lines are missing or show different information, add them or change them to match the ones above.
You should also check that the King's Quest VII icon's properties indicate the correct working directory. To do this, click once on the King's Quest VII icon to highlight it. Then press ALT-ENTER (Windows 3.1) or right click (Windows 95) to access the icon's properties. The command line should read:
C:\SIERRA\KQ7\SIERRAWS.EXE C:\SIERRA\KQ7\RESOURCE.WIN (versions 1.4 and 1.51)
C:\SIERRA\KQ7\SIERRAW.EXE -o C:\SIERRA\KQ7\RESOURCE.WIN (version 2.0)
The working directory should be your CD ROM drive, for example, D:\. If your CD ROM drive is another letter, substitute the appropriate letter. Click on OK when the working directory is correct.
lemme know if the issue was resolved..
Dec 03, 2009 | Video Game Consoles & Games
After instaling a downloaded mtx: mototrax for mac, when a double click to start playing its asks for a cd-rom.
open that game file and copy the file from crack or devience folder, after that copy that to the directory where you installed that game, they will ask you to replace a file, click yes button. now run the game
Nov 09, 2009 | Aspyr MTX: MotoTrax for Windows, Mac
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Error Message 'F:\ setup.exe is not a valid win32 application'
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
Bad file
Mar 18, 2009 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
