How can i use my cam and mic? i am using msi u100 series
SOURCE: can't find the wireless antenna on my msi u100 series laptop
Not really sure what you are expecting. The wireless antenna is within the computer--you won't see it.
What you will need to do is to turn the wireless networking on. This is done in some computers with a small switch on the case (in this case, there is usually a light that comes on when you turn the switch on). In other cases, you will have to use the Fn key plus one of the special function keys at the top of the unit (has a picture representing a wireless connection on it--possibly something like an antenna).
If this fails, go into your network connections and see if the wireless connection is actually turned on. If you have Vista, this is sorta easy as you click on "connect to" and then choose "wireless network"
SOURCE: MSI wind U100 built in webcam
Try to press FN key together with F6 to makes the webcam works
SOURCE: built in webcam not working MSI wind notebook u100 series
please chek ur webcam status..that on or off. if off press fn + f6.
SOURCE: The bluetooth turns on using FN + F11 it should
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
Bluetooth LED indicator glows blue when Bluetooth function is enabled.
Both LED indicators glow green and blue at the same time when both
functions are enabled.
Both LED indicators go out when both functions are disabled.
Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
