Question about Logitech Cordless Mouse
Snapped USB fob for Logitech RX650
Is it possible to buy replacement USB fobs for a Logitech RX650 mouse? My son has just attempted to pick up laptop and in process snapped the USB fob.
  • 185 Answers
The quick answer is yes, it is possible to replace and you'll find a suitable plug here http://www.maplin.co.uk/Module.aspx?ModuleNo=43998
The question is, will you be able to fit the new plug yourself and the answer to that question is not so easy. USB plugs are multi connectors, which means there are several connection terminals associated with the plug. The wires will need to be soldered to the correct places and this would not be a job for someone without soldering experience. Computer mice are not expensive these days and you may fine it easier and cheaper to look for a replacement on eBay. Do also check the USB socket on the laptop too, just to make sure it has not been stressed too much.
Best wishes....
Posted on Oct 20, 2008
Do i have to have the bluetooth fob to use the wireless mouse model ls6400r
You have to use the fob that came with the mouse. No other kind will work with it. There are 17 channels in the blue tooth spectrum and the receiver is paired frequency wise to the channel used by the mouse and keyboard.
Aug 09, 2017 | The Computers & Internet
How do you work 2006 street glide push button key fob
1 long push on the remote turns it on and 2 quick clicks turn it off.
Disarming function may require practice. The key fob button must be pressed twice within 1.5 seconds to send the disarm command. The action is very similar to double-clicking a computer mouse. Light quick taps work best; very hard or very slow taps are less likely to work. The key fob sends a RF signal to activate all remote TSSM functions. The left front turn signal switch wire serves as the vehicle's antenna. If the TSSM does not respond (no confirmation at arming/disarming system) or responds weakly (limited range, won't consistently arm/disarm or synchronize),
Verify key fob battery voltage is at least 2.9 volts. Replace the key fob battery every 2 years.
Interference from physical surroundings may affect RF transmission. Place the fob next to left hand grip and disarm with two clicks or move the motorcycle to a new location and try again.
Check for damage to antenna wire. Does left turn signal work?
After a battery disconnect, the TSSM will not enter the configuration mode on the first attempt. All attempts to assign a fob or enter the configuration mode will require at least two attempts.
The TSSM system uses batteries in the key fob and siren. These are the only parts requiring periodic maintenance.
Battery Replacement
Open the key fob case, place a thin blade between the 2 halves of the case, slowly twist the blade remove and replace battery positive + side down, use a Panasonic 2032 or equivalent, align the case and circuit board, snap the case halves together, while standing next to the motorcycle, press and hold the key fob button for 10 to15 seconds until the security system responds with two turn signal flashes/siren chirps.
May 04, 2014 | Harley Davidson Motorcycles
Ex110 keyboard and m505 mouse
No it will not sensors are mostly model specific. Walmart has cheap sets that require now only a usb fob plugged in as the sensor 40 bucks
Apr 07, 2012 | Logitech Cordless Desktop EX110
The thing that fits in the computer for the cordless mouse has broken,can I get replacement or do I need new mouse ?
Usually a whole new mouse/fob combination is purchased at a store as a set.
But, Logitech may sell the fob separately foir a lower cost.
I would check with Logitech to see if they would sell you the usb transmitter or fob for the mouse separately.
http://www.logitech.com/en-roeu/349/4872?wt.ac=ps'5055
Look at the above website for examples of some 'receivers' for your mouse.
Dec 10, 2010 | Logitech Cordless Mouse
2001 dodge ram, key fob batterys are good and the inside looks good but not able to use it to unlock or lock doors and use the panic
Th fob may need to be re-programmed. It's different for all cars, but it should have it in your manual. Do you have only 1 fob? If not, does the other work? My best suggestion is to buy another fob from ebay, which is where I pick mine up all the time. These will need programmed, but a little looking on the internet will give you directions on how to program the fob, or the seller could give you instructions.
Sep 27, 2010 | Dodge Pickup Cars & Trucks
Key board not working ...batteries replaced.... mouse operates ok
You may have to make sure that the software for it is installed correctly and that the usb fob is inserted correctly.
Try to uninstall the software drivers for the keyboard and follow the instructions for reinstalling the keyboard along with the fob to make sure it can communicate with the computer.
Hope this helpe.
Jul 14, 2010 | Logitech 967437-0403 Keyboard
Belkin wireless travel mouse not connecting to Mac
If you have a usb extension cable try plugging it in so you can place it on a firm surface when you press the sync buttons. Have heard of some issues with activating both mouse and fob buttons at once because of difficulty in reaching the fobs sync button.
Aug 13, 2009 | Belkin F5L017 Mouse
The logitech rx 650 mice is no longer recognisable on my dell inspiron laptop 1525 it was working well untill a few days ago now its not being recognised
If you have the software, then uninstall the RX650 software. Then re-install software and drivers. You can go to Logitech and download all required software and updates.
May 11, 2009 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Broken wireless mouse receiver
Try amazon.com or tigerdirect.
May 10, 2009 | Computers & Internet
Logitech Cordless Mouse Logo
875 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
