Question about Samsung HCL4715W 47" Rear Projection Television
TV Flickers red lines across tv screen
I have a Samsung HCL4715W 47 in. Rear Projection Television. All of a sudden I have this problem with a red flickering on the screen. If I peek through the back of the tv into the vents I can see a red flickering. Is my TV hosed? Thanks for any help Justin
  • The Daniel Feb 19, 2009
    Had a red flicker and horizontal red lines across the screen after it warmed up. Replaced Red Crt, no effect, replaced Flyback transformer and HV distributor. When I turned it back on, the new Red CRT cracked and leaked fluid down to the cathode and pins. I put the old CRT in, and it seems to operate, but red is blurry, convergence is out, and it still flickers. Running out of patience with this. Any ideas. Have a meter, an ocilloscope even, but no more ideas. I'd really like to have a solid idea about what is faulty before ordering more new parts. I'd probably have called a tech if there was anyone to service it that didn't charge $500 just to look at it.
  • 1,476 Answers
Sounds like you have an intermitant overdrive situation on the red CRT. This could be caused by a bad component on the Red CRT board, an intermittantly shorting CRT or the circuitry in the main board. You should not run it until the problem is resolved as you could damage the CRT if it is not already bad. This is something that unless you are a qualified tech you are not going to have any success resolving. It should not be very hard for a good tech to diagnose the problem. Costs will depend on the part which is bad. If it is the red CRT it probably is not worth fixing, but it could be a 50 cent capacitor. Certainly worth the cost of a service call. Good luck.
Posted on Jul 12, 2006
SOURCE:
HCL4715W 47 in. Rear Projection Television: Wheb the TV is turned on the screen is fine, howev...
Yes,this tv can be fix it have convergence problems.The convergence board the 2 STK covergence ICS are defective and some or all it resistors are dead.The shop will cost u $300-350 for parts and labors.
May 16, 2010 | Samsung HCL4715W 47" Rear Projection...
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Dlp
most likely a bad optical block part price between $450 - 550
Apr 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Tv will not turn on
If your convergence ICs are bad set will not come on 1 of the ICs controls Off/on STKs big black ics replace both STK392-020s use 040s For Parts call 1-800-223-3205. www.electronix.com
Jan 03, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W
It is very possible that there are some parts in the power supply that are failing. This can be from voltage regulation, filtering, or noise problems.
Jerry G.
Jul 08, 2008 | Samsung HCL4715W 47" Rear Projection...
Red Curvy Lines across top of screen (Unable to converge)
It sounds like a convergence problem to me also. The average cost to repair this TV is around $450.00-$500.00.
Call another service company that is factory authorized to service your TV. Also, try calling your manufacture and explaining your concerns and ask if will pay for repair or at least for the parts. Have model, serial numbers and purchase date at hand.
Feb 23, 2008 | Samsung HCL4715W 47" Rear Projection...
Flashing red lines on Samsung hcl4715w rear projection
The convergence board wont correct the problem. You need to replace the two Convergence ICs on the sub board STK392-040 and you will be back to normal. See my response above. That site will help you get it back to normal.
Dec 21, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
233 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
